Old 09-09-2008, 10:19 AM   #1
quirino18
My Ride: 2000 323CI AUTO TIPT
Question 323ci fuel pump has no power?
i check for power and it doent have any.
can someone help me out by pointing out what else to check from relay towhatever am missing? may be the emergency shut-off switch if any? and where are this parts located?/
i check fuses and there fine!
thanks in advance for any help given!!
quirino18 is offline   Reply With Quote
Old 09-09-2008, 10:56 AM   #2
TKC
My Ride: 330cic & R6
Send a message via AIM to TKC
how did you check for power at the pump?
what is wrong with your car, it won't start?
I did a DIY write up on how to change out the pump, but I'm not sure that's your problem?
http://forum.e46fanatics.com/showthr...ight=fuel+pump
EUROPROJEKTZ - Director, NorCal Chapter
TKC is offline   Reply With Quote
Old 09-09-2008, 12:01 PM   #3
quirino18
wont start, i used a multy meter at the harness that conects to the pump
update! 9-9-08
i removed the pump and in fact it has power but the pump gets stuck, so i removed it and taped it right at the motor and it turned on again!! so bottom line the pump is bad!! found a place where the pump costed me $136.00 ruber seal $7.00 free shiping!!! original pump VOD pump
if anyone need the site just pm and i'll send it to you guys!!
