Sponsored by BimmerWorld
Old 09-09-2008, 09:49 AM   #1
msport02
My Ride: 2002 318CI Coupe M
Unhappy Front left wheel squeek / binding question...
I recently purchased my 2002 BMW 318CI Coupe, i know this engine size does not exist in the USA but im sure the brake/wheel setup will be similar to one of a larger engine.
It has done 74,000 miles and the pads + discs have been replaced.
I have been advised to check that my brakes are not binding when to car is in motion - to do this would it be a simple process of jacking the car up, releasing the handbrake and spinning the wheel to ensure no binding??
The squeek occurs when i drive at around 5mph, the sound is coming from the front left wheel and seems to become louder when turning. However, when i accelerate the squeek stops.
Any advice on what maybe causing this or what i should be checking would be greatly appreciated!
From across 'the pond', thanks!
msport02 is offline   Reply With Quote
