Sponsored by BimmerWorld
Old 09-10-2008, 12:44 AM   #1
koven
My Ride: 330Ci
different springs in front and back
so my fronts low enough but i want lower in the back, can i just change the rear springs to something else?
koven is offline   Reply With Quote
Old 09-10-2008, 12:53 AM   #2
Arrows
My Ride: 2000 323i.
Send a message via AIM to Arrows Send a message via MSN to Arrows
Yes you can, as long as the fronts are the same, and rears are the same, I don't see a problem. It's just like coilovers with different spring rates.
Arrows is offline   Reply With Quote
Old 09-10-2008, 12:56 AM   #3
frobie15
My Ride: has a door star
Send a message via AIM to frobie15
And that reason, my friend, is why you go with coilovers rather than springs
Go ahead, ask me a question... Check out the CopTalk thread in the California forum
Thank you Sam
frobie15 is offline   Reply With Quote
Old 09-10-2008, 01:04 AM   #4
koven
My Ride: 330Ci
i fail
Old 09-10-2008, 11:33 AM   #5
n2Bimmer
My Ride: Loves Corners
yes you can, thats what i did.
Old 09-10-2008, 11:39 AM   #6
VALMONT
The De46vil's Army
VALMONT's Avatar
My Ride: 325Ci, Passat
Send a message via AIM to VALMONT Send a message via MSN to VALMONT
back in the early days of fanatics there was the jawknee setup (sp?)
it was basically e36 M3 springs in the rear if i remember correctly.
VALMONT is offline   Reply With Quote
Old 09-10-2008, 12:25 PM   #7
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
^ I believe they were H&R Race springs, E46 non-M in the front, and E36M in the rear.
The OP should get coils. Especially if he is considering mixing brands front to rear, that just seems silly!
-Brendan
Old 09-11-2008, 08:19 AM   #8
C Digital 323CI
Eurowerkz Midwest
C Digital 323CI's Avatar
My Ride: 2006 E90 330i
Koven, You know the issues I am having with my iForged, so I am actually thinking of keeping my UUC v.2 fronts and putting in my stock sport spring in the rear. This will bring up the fender to the top of the tire and also firm up the spring rate so I won't rub. My UUC v.2 rears sit pretty low so if you're thinking about just getting new springs I will sell you mine for cheap. PM me if you want to talk more about it.
Edit- check your PM Koven
-Chad - Eurowerkz, Midwest Director
SPONSORED BY: | TOYO Tires | WheelSTO | Level Industries |
C.Moon Photography
Twitter
C Digital 323CI is offline   Reply With Quote
Old 09-11-2008, 09:46 AM   #9
koven
My Ride: 330Ci
i'll probably get coils in the future but spending $1000+ to get my rear a little lower right now isn't worth it to me
so i'm guessing it's ok to mix springs
thanks
Old 09-11-2008, 11:05 PM   #10
frobie15
thanks
$1k for coilovers?? Check out the ST setup. I got mine installed for less then a grand!
Thank you Sam
Old 09-12-2008, 12:49 AM   #11
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
LOL I used to run that when I first got my car...
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 09-12-2008, 04:09 PM   #12
koven
My Ride: 330Ci
any more details/link?
Old 09-16-2008, 02:03 PM   #13
frobie15
Call Sam at Autotalent. Get a price from them.
Thank you Sam
Old 09-16-2008, 06:02 PM   #14
xPhantom
My Ride: 2003 BMW M3 (TiAg)
Send a message via AIM to xPhantom
or.. you can take out your spring pads in the rear.
i did that and it dropped a pretty good amount.
before:
after:
xPhantom is offline   Reply With Quote
Old 10-04-2008, 12:09 AM   #15
00bmw323
My Ride: 00 323/91 integra RS
before:
after:
will this work?
-Jorge
All low no go
00bmw323 is offline   Reply With Quote
Old 10-04-2008, 01:20 AM   #16
frobie15
Originally Posted by 00bmw323 View Post
will this work?
For you? NO! Not unless you let me have that engine cover!!!
Thank you Sam
Old 10-04-2008, 11:45 AM   #17
00bmw323
-Jorge
All low no go
Old 10-15-2008, 07:48 PM   #18
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
any noise or weird ride from removing the spring pad? I have a friend that wants to do this
/_________\
O==[][]==O
