Sponsored by BimmerWorld
Old 09-12-2008, 05:53 AM   #1
goyongj
My Ride: 02 325ci
Did I install it right?? pics
I installed koni yellow shocks.
I didn't know what to do with the dot in the picture......
how far should it sit? where is it supposed to face??
NY->Salt Lake City within 48 hours
goyongj is offline   Reply With Quote
Old 09-12-2008, 06:00 AM   #2
drippabmw
My Ride: Fully Built S/C M3
that dot is suppose to go in betweeen the groove where you put the bolt through.
drippabmw is offline   Reply With Quote
Old 09-12-2008, 06:01 AM   #3
drippabmw
also its hard to see but I am wondering if that shock has to come down some more.
Old 09-12-2008, 06:37 AM   #4
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
when you align the dot with the slot caused by the bolt gap - the strut will drop down (you may have to force it down/force the control arm brake assembly up) about 1/2" to 3/4"
/_________\
O==[][]==O
Old 09-12-2008, 09:23 AM   #5
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: Project 330xi
May even help to place a floor jack under the control arm and jack it up into the clamp.
-Gary
DiscoStu is offline   Reply With Quote
Old 09-12-2008, 10:35 AM   #6
xPhantom
My Ride: 2003 BMW M3 (TiAg)
Send a message via AIM to xPhantom
yeah that bump is supposed to go in the slot where the pinch bolt pinches.
and most people use a jack to push the control arm up.
xPhantom is offline   Reply With Quote
Old 09-12-2008, 10:51 AM   #7
330i ZHP
330i ZHP's Avatar
jack yes, if not avail use strength
/_________\
O==[][]==O
Old 09-12-2008, 12:47 PM   #8
TxZHP04
My Ride: ESS TS2+ ZHP
I found it easiest to support the control arm with a jack, insert the lower end of the strut into the collar while the upper strut mount isn't bolted to the tower, tighten the lower bolt, and then raise the control arm while guiding the upper mount into position.
