Old 09-13-2008, 06:13 PM   #1
vrado
My Ride: 330i 530
Clutch Question
On my 330 ZHP can I put a m3 fly wheel pressure pate and clutch into my tranny??????????
vrado is offline   Reply With Quote
Old 09-14-2008, 09:27 AM   #2
TxZHP04
My Ride: ESS TS2+ ZHP
No, they are different.
Old 09-14-2008, 10:54 AM   #3
vrado
My Ride: 330i 530
What's different the tranny in itself, bolt pattern to the motor, bell housing, what?????????????????????? Because I know that the whole clutch pack is different including the fly wheel.
Old 09-14-2008, 11:37 AM   #4
TxZHP04
Sorry but I can't provide an in depth engineering analysis of exactly what is different and why. I do know that the inputs shaft splines are different between the transmissions. Bell housing and bolt pattern should be the same as I believe the transmissions are interchangeable.
Why are you so interested?
Old 09-14-2008, 01:53 PM   #5
vrado
My Ride: 330i 530
Clutch
From what I am hearing the M3 clutch is a bit stronger.
Old 09-14-2008, 03:29 PM   #6
TxZHP04
Makes sense given the greater output of the M3 motor. If you need a stronger clutch for a 330 though, you'll need to go aftermarket.
Unless you are very heavily modded, the stock clutch is more than enough. I'm running over 320 ft-lb (at the flywheel) on my stock clutch at 73k miles with no problem.
