225/40/18 or 235/40/18 front tire on my HM2? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by The Tire Rack
Old 05-14-2002, 05:52 PM   #1
miata168
any idea?
miata168 is offline   Reply With Quote
Old 05-14-2002, 05:59 PM   #2
Cal
Still a fanatic...
My Ride: 08 GL450/04 E320/98M
I would stick with 225/40ZR18 up front. Reasons being that this is the "correct" size if you want to keep the overall diameter the same as stock. Second, it should definitely be more "fender rubbing" free than the 235/40ZR18 (although this shouldn't rub either). The 235/40 will give you slightly better grip though.
Cal is offline   Reply With Quote
Old 05-14-2002, 06:03 PM   #3
Clem
Alpha Male
Clem's Avatar
My Ride: Twin Turbo'd Beast
NOTHING LESS than 235/40ZR18
225 is not a wide enough tire for 8.5" wide rims. The lip will stick out farther than the sidewall.
Clem is offline   Reply With Quote
Old 05-15-2002, 07:59 AM   #4
rvnvet
My Ride: 2000 323i Sport
If your wheels are 8.5" then you should go with 235x40's.. A 225mm tire is good on a 8" wheel but too small for a 8.5". I didn't do my homework and I put 225x40's on 18x8.5 Breyton Inspirations and the wheel sticks out past the tire. It's not that noticeable until you get up real close to the wheel...I'll be getting 235's on mine when the old tires wear out...The 235x40's will fit front and back with no rubbing... Here is a pic of my 00 323i sport.
rvnvet is offline   Reply With Quote
Old 05-15-2002, 09:37 AM   #5
roz121xi
My Ride: 330xi
would it be possible to put 235/40/18 on all four 18"x8" rims? i know 225 is the recommended but i figure the 235 would offer a little more rim protection... thoughts/experiences?
2002 330xi
roz121xi is offline   Reply With Quote
Old 05-15-2002, 09:58 AM   #6
Clem
Alpha Male
Clem's Avatar
It would fit fine. 225s will offer some rim protection as well.
Old 05-22-2002, 06:34 PM   #7
qt330ci
My Ride: '01 330ci
SO YOU THINK IT IS BETTER TO HAVE 235 ALL AROUND OR 235 FRONT AND BACK 245 . EVEN YOU LOWER YOUR CAR WITH H&R
qt330ci is offline   Reply With Quote
