Old 09-16-2008, 07:17 PM   #1
HD325i
My Ride: 2002 325i
Throttle Responce
I recently installed a K&N cold air intake on my 2002 325i. Now, I have noticed two things.
1. There seems to be a 1-second lag time between stepping on the gas and accelerating. Did the K&N that caused this delay or is it a BMW thing? Can this be corrected? If so, how?
2. After I turn the key off and wait about a second or two I hear , for lack of a better word, a sucking sound from the K&N filter. It's kind of like someone catching there breath after holding it too long. Is this normal for a air intake? It certainly did not hear this when the factory air box was in. Did I screw something up by adding the K&N?
I appreciate any feedback on this - thanks!
HD325i is offline   Reply With Quote
Old 09-16-2008, 07:49 PM   #2
BassRocker
My Ride: 2001 325 cic
I put the same one on my 01 325Ci and I didnt have this . Just some ( air sucking sound that I had to get used to ) when i push the gas..
Mike
BassRocker is offline   Reply With Quote
Old 09-17-2008, 12:32 AM   #3
Chris-TK
My Ride: Mk VI GTI
The sound you hear after the car is off is a normal decompression. Most cold air intakes, if not all have this. Sounds like a "sssshhhuuuhhh".
K.
Chris-TK is offline   Reply With Quote
Old 09-17-2008, 03:42 PM   #4
HD325i
My Ride: 2002 325i
Chris - thanks for the reply. Do you have the slight delay in your acceleration also? I have been told that is a BMW factory electronic throttle setting to keep people from spinning the rear tires. Is there a way to reduce or eliminate the delay? Chip upgrade maybe?
Old 09-17-2008, 07:56 PM   #5
Chris-TK
My Ride: Mk VI GTI
I also have the Dinan Stage II software. I haven't really noticed that much of a lag, standard auto lag I guess. You could always get an ECU software upgrade and an auto tranny upgrade.
K.
