Old 05-14-2002, 06:59 PM   #1
javidkhan
My Ride: 318 TDS
Question 318 TDS Starting Problem
I recently Purchased a 318 tds (year 2000 model E36). It Had sustained water damage (fresh water) but was drivable.
It now does not start, as a result, the ECU has been changed, the engine loom and the immobiliser box, Oh also one of the solenoid switches (for good measure!) Still not sure what the problem is.
There doesn't seem to be any diesal comming out of the injectors into the engine.
Someone suggested that there could be air in the system and so was advised to attemp on cranking the engine, a dozen times or so (i'm currently on 6 times, as the battery keeps going flat!).
Anyway, where should I go from here?
Thanks in anticipation.
Jay, UK
javidkhan is offline   Reply With Quote
Old 05-14-2002, 07:02 PM   #2
Clem
Alpha Male
Clem's Avatar
My Ride: Twin Turbo'd Beast
IF there's no diesel coming out of the injectors the next obvious step is to check your fuel pump.
Clem is offline   Reply With Quote
