Old 09-17-2008, 11:04 PM   #1
Chris-TK
My Ride: Mazda
DIY: How To Fix Your Falling Door Trim
Okay, so I've seen tons of people describing different methods to fix the infamous falling door trim that's an inherent flaw in our E46's. I tried using a few different types of adhesives with no luck. Most of the adhesives didn't adhere well enough to hold the trim for long. Nothing could hold the trim in place long enough to allow the adhesive to take.
The baseball bat wedged between the seat and the trim didn't work. Masking tape to hold the trim in place while the adhesive dried didn't work either. FINALLY I came up with a solution.
You'll need some Gorilla Glue Gel to apply to the back of the falling trim. No need to clean the surface before applying like the directions say. You'll also need 2 or 3 Irwin 4" 150 lb. Quick Grip vice grips that can be bought at any major hardware store to help hold the trim in place while the glue sets.
The trick is that it takes time to to finish the whole trim piece. Start slow by applying the glue to about 6 inches of trim at a time and place the vice grips on the trim and the outside window trim piece. Make sure you angle the grips well enough that the outside window trim fits in the notches so they won't move. Be sure not to apply too much glue because when the pressure is applied it can leak out through the sides and onto the headliner. Let the section sit for about 30 minutes and repeat this process section by section until you're done.
Gorilla Glue Gel and 2 or 3 Irwin 4" plastic 150lb. vice grips.
Glue section by section and make sure the notches on the yellow pieces of the grips fit on the outside of the window trim as pcitured:
K.
Chris-TK is offline   Reply With Quote
Old 10-08-2008, 11:03 AM   #2
wmarcel
My Ride: 325ci '01
Thanks for the write-up. Do you happen to know where to purchase a new door trim? Mine is completely worn off. Might as well get a new one and apply your method.
wmarcel is offline   Reply With Quote
Old 10-08-2008, 11:05 AM   #3
Chris-TK
My Ride: Mazda
If you do my DIY you won't need to get a new one. The new ones run about $250 you can get one from Tischer at getbmwparts.com go to their E46Fanatics Specials. The thing is that the felt trim piece is attached to the rubber door seal as well, so it's all in one. The whole piece is kept in place by little clips. The trim falls when these two pieces separate, leaving the rubber attached, but the trim hanging.
K.
Old 10-08-2008, 11:33 AM   #4
wmarcel
My Ride: 325ci '01
I see. Will try your method then. Thanks, man.
Old 10-09-2008, 01:00 AM   #5
deafboy
My Ride: 2000 323Ci
yeah...thats more or less what I did. It's held up for over three years.
-Cole aka bigtall*****
Originally Posted by Owtlaw333 View Post
You'll always be pretty in my eyes, Cole :luv:
Originally Posted by Chrissspyy View Post
i was like passed out while she's shoving the entire bar in my mouth. :rofl: :rofl:
deafboy is offline   Reply With Quote
Old 10-09-2008, 01:26 AM   #6
Drew@Swift Motorworks
Drew@Swift Motorworks's Avatar
My Ride: Scooty Puff Jr
Mine came down after about 6 glue attempts. Sometimes it lasted a couple of months, sometimes a day. I finally gave up and ripped it off. Doesnt look too bad either.
Drew@Swift Motorworks is offline   Reply With Quote
Old 10-09-2008, 01:27 AM   #7
Chris-TK
My Ride: Mazda
Did you clamp it? What glue did you use?
K.
Old 10-09-2008, 02:50 AM   #8
towlie
My Ride: 02 ///M3
Be careful with this stuff. My brother did this for me, but ended up using too much glue and it has been really difficult to get off the trim. In fact there is still a bit of yellowish discoloration, thankfully its not in a noticeable spot (back part of the trim).
towlie is offline   Reply With Quote
Old 10-09-2008, 01:37 PM   #9
deafboy
My Ride: 2000 323Ci
he used normal gorilla glue didnt he?
that stuff does expand a little bit so you have to apply it lightly (I used the original stuff too, since their clear super glue wasnt out at the time).
Old 10-09-2008, 01:49 PM   #10
KaOsTiK
My Ride: 2003.5 M3
my solution was to go to the dealership and complain about it until they replaced it... but good write up
2003.5 M3 (current project)
2000 Acura 1.6 EL (best EL...period)
KaOsTiK is offline   Reply With Quote
Old 10-09-2008, 01:51 PM   #11
JK1150
My Ride: 2004 325CI
i got both my drivers and passenger side replaced at separate times, and I swear the one they replaced it with looked like it was a different material than the old one. maybe BMW owned up to their mistake and revised it for replacements?
yea, I got my car back from Inspection II and the thing feel down right when I opened my window. I said that I know it's a common problem and not 100% their fault, but I just paid a couple hundred to them and I got my car back with this thing hanging down. It was obviously nicked at some point, so they were reasonable and replaced it.
JK1150 is offline   Reply With Quote
Old 10-09-2008, 11:08 PM   #12
moomber
My Ride: 330ci
wow, that's EXACTLY what I did and it works !
now, how do you fix the rubber that cracks for the rear vent windows?!?!
moomber is offline   Reply With Quote
Old 10-09-2008, 11:13 PM   #13
Maniac
My Ride: E46 325Ci R6 07Ram
i used crazy glue and no clamps and mine has lasted 14 months so far
<img src=http://i194.photobucket.com/albums/z76/E46Maniac/signumber2.jpg border=0 alt= />
Originally Posted by 46_coupe View Post
Attractive and stable works for me...I'd rather help wifey program the stove clock than wonder if she purposely left the gas on :eek:
19" vmr v710s| falken 452s 235/265s| orion v2| CF Wrapped trim |35% tint all round| alcantra shift/ebrake boots | HR race
Maniac is offline   Reply With Quote
Old 10-10-2008, 01:20 AM   #14
deafboy
My Ride: 2000 323Ci
that you actually have to replace...fairly simple if I remember correctly. Theres a DIY somewhere around here.
Old 10-10-2008, 01:24 AM   #15
Chris-TK
My Ride: Mazda
That black original Gorilla Glue is super messy.
Not all of us have the luxury of having warranties anymore. I did have my trim replaced a few times under warranty, but now the dealer wants $250 to replace it. F that, I'll use some glue and clamps.
You have to replace the entire rubber as already said. Next time use some 303 Aerospace Protectant to protect the rubber from harmful UV rays to prolong the life of the rubber.
K.
Old 10-10-2008, 05:46 AM   #16
I used a bunch of diferrent glues, epoxys, super glue. I clamped once, the first time and it stayed for a couple of months. then after that I tried using a rope that i rigged up around the trim the trim and through the sunroof (Yeah i know ghetto... but i didnt have access to clamps). The previous owner also had a body shop do it.
From what Ive heard It just wont work. I have a friend in the book binding industry and he deals with these sorts of materials all the time. He told me it just wont hold forever. The rubber is not porous and both sides your gluing together are rubber it just wont stick. He said glue will stick to one side but never both. I took it to a body shop too and they said the same thing.
I'm sure the clamping really helps and I'm not knocking your DIY, its great, but in my experience gluing it isnt a permanent solution
edit: I was going to joke that the only way to get them to stay up would be to weld them. But that got me thinking... How about melting the trim and the weather stripping together, sort of in the way the door panels are held together with those plastic welds?
Old 10-10-2008, 11:39 AM   #17
Chris-TK
My Ride: Mazda
Seriously, try the gorilla glue and clamps. Mine's been rock solid for months.
K.
Old 10-10-2008, 12:58 PM   #18
metalmind1
My Ride: 328ci
Any sort of weather srtip adhesive will work excellent also
metalmind1 is offline   Reply With Quote
Old 10-12-2008, 11:35 AM   #19
JCsE46
(oOO \ (||||)(||||) / OOo)
JCsE46's Avatar
My Ride: 03 E46 JB, 08 MBE350
Send a message via AIM to JCsE46 Send a message via MSN to JCsE46
Seriously, don't you guys ever think just to buy the plastic expanded clamp that hold the trim? It's the No. 14 of the REALOEM.COM. Here's link http://www.realoem.com/bmw/showparts...67&hg=51&fg=20. That's all I did was to replace these clamps. These clamps are just $1.29 ea. - PN 51138204858 from Tischer. First I partially detached the molding trim from the front and leave it hung half way for a while then I removed the broken clamps by drilling out at the center using a small drill bit enough to remove the clamps then placed a new clamp in the existing hole. Re-clipped the molding trim back and back to normal.
JCsE46 is offline   Reply With Quote
Old 03-19-2009, 10:12 PM   #20
WBVenom
My Ride: Car 54
You're not talking about the same trim we are. The trim we're speaking of (as clearly shown in the OP's pictures) is the felt-covered rubber lining glued to the inside of the weatherstrip door seals. No clips involved.
WBVenom is offline   Reply With Quote
