Thread Tools Search this Thread Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Old 03-19-2009, 11:14 PM   #21
WBVenom
My Ride: Car 54
This weatherstip adhesive is excellent: http://www.pelicanparts.com/cgi-bin/...5%20oz.%20Tube
WBVenom is offline   Reply With Quote
Old 05-21-2009, 03:56 PM   #22
Chris-TK
My Ride: Mk VI GTI
UPDATE:
It has been 8 months and the trim is still holding strong in the places where I applied the Gorilla Glue Gel as per my original post. Although now it has started to droop in the areas that were previously okay. Now I have to break out the vice grips and gorilla glue again for these new sections.
K.
Chris-TK is offline   Reply With Quote
Old 05-21-2009, 04:26 PM   #23
wmarcel
My Ride: 325ci '01
I tried but unfortunately the trim (both sides) was in such bad shape that I had to replace it with a new one. (getbmwparts.com for ~ $264) Looks brand new now.
wmarcel is offline   Reply With Quote
Old 05-21-2009, 04:30 PM   #24
Chris-TK
My Ride: Mk VI GTI
I'm not giving in that easily!!!
K.
Old 06-06-2009, 10:33 PM   #25
SK328CI
SK328CI's Avatar
My Ride: 2006 Jeep SRT8
piece of **** bmw... this is the 3rd time my trim started to droop in 2 years time. gotta go to auto store and get some glue. so embarrassing i dont even wanna roll down my windows
SK328CI is offline   Reply With Quote
Old 06-07-2009, 09:32 AM   #26
thereal007
My Ride: 2000 328ci
hey guys I'm working on a complete replacement. when i got my car the complete passenger side was gone and the drivers side was falling. I'm taking pictures and will post them when I'm done. so far so good. bmw only sells it as an attached set felt and weather stripping for 300 bucks each! mines gonna look like new for about 20 bucks. keep an eye out for my diy once i finish and write it up.
thereal007 is offline   Reply With Quote
Old 06-09-2009, 06:54 PM   #27
2001BlackOnTan
My Ride: 2001 330Ci
I've found that it helps to use small (and thus flexible) wooded paint stirrers between the clamp and the weatherstripping / trim as this spreads the clamping force over a wider area (for better glue adhesion) and also helps keep the clamp from making an indent on the fabric trim. It also helps make the trim stick on all parts of a curved surface, not just where the clamp happens to be.
2001BlackOnTan is offline   Reply With Quote
Old 06-09-2009, 06:55 PM   #28
2001BlackOnTan
My Ride: 2001 330Ci
And the glue that's worked well for me on the weatherstripping is "Amazing Goop" contact adhesive and sealant.
Old 06-10-2009, 10:03 PM   #29
smuggler617
My Ride: E46 328ci, E36 M3
Home Depot has "Perfect Glue" again by Liquid Nails. This with the clamp method works perfect.
smuggler617 is offline   Reply With Quote
Old 07-14-2009, 06:49 PM   #30
chantz316
My Ride: bmw 323ci
the only thing that sux is when the trim comes down behind your seat and then the leather begins to come undone and show that ugly yellow foam **** and you cant get it back in place
chantz316 is offline   Reply With Quote
Old 07-14-2009, 11:12 PM   #31
als00328ci
My Ride: 2000 328ci --> SP
Good write up, I though I was the only one with a falling window trim.
als00328ci is offline   Reply With Quote
Old 07-14-2009, 11:35 PM   #32
Chris-TK
My Ride: Mk VI GTI
Sadly no. Even the savviest of E46 drivers suffer from this retarded problem.
K.
Old 07-15-2009, 01:43 AM   #33
paraklas
My Ride: ESS TS2 320ci
Just an update, after 2.5 years the glue I used seems to be holding very well. This will be the 3rd summer and hopefully without any issues
Old 08-07-2009, 12:41 PM   #34
aaronu
Content free since 1994
aaronu's Avatar
My Ride: Nothing. I ride.
Saaaaaaaaaaaaweet thread.
Drooping door seal trim is my nemesis.
I tried all sorts of stuff from super glue to rubber cement and nothing really worked. Left side held up for almost a year with good rubber cement but it's starting to go. WTF.
Right side trim was replaced under warranty but just this week, the replacement is beginning to fall.
My local dealer wanted $480 PER SIDE to replace the trim.
Originally Posted by aaronu View Post
"Hello Mr. or Ms. McDonald's drive-thru person. Why, yes. I do drive a POS."
I'm going to try the ChrisTKHarris method since I can buy the gel Gorilla glue locally.
Oh snap. I can't follow the instructions! My clamps are not Irwin brand.
Seriously, thanks for posting. I now have hope.
RIP 11/25/2009
2004 Mazda RX-8 6MT, Nordic Green
aaronu is offline   Reply With Quote
Old 08-07-2009, 12:59 PM   #35
Chris-TK
My Ride: Mk VI GTI
K.
Old 08-09-2009, 01:30 AM   #36
brodaiga
My Ride: 330ci
I just did this with electrical tape holding everything in place and gorilla glue, it is drying right now.
brodaiga is offline   Reply With Quote
Old 08-09-2009, 01:37 PM   #37
Chris-TK
My Ride: Mk VI GTI
I never found that any kind of tape could hold the trim firm enough.
K.
Old 08-19-2009, 08:18 AM   #38
Sentaruu
My Ride: Xterra
one thing i would add to your DIY would be to use a wash cloth, or any other clean rag as a buffer between the top arm of the clamp and your car's paint/trim(thats assuming the clamp doesnt have a rubber pad attached to it already).
nice writeup
Sentaruu is offline   Reply With Quote
Old 08-19-2009, 11:19 PM   #39
adv_round
My Ride: 323ci
My 2000 323ci did this to me today... so disappointed. I'm also new owner of three 4" clamps, Irwin should cut you a commission check
When I looked at sagging piece of trim, it appears the factory applied glue to two tiny tracks near the edges and leave the middle dry.
Are you applying Gorilla glue to entire interior trim (without going over the edges of course)? or just in some spots?
adv_round is offline   Reply With Quote
Old 08-19-2009, 11:21 PM   #40
Chris-TK
My Ride: Mk VI GTI
nice writeup
Good suggestion.
I applied it to the entire section that needed to be re-applied. Be sure not to use too much as when the clamps apply pressure it will squeeze out onto the visible parts of the trim.
K.
