Po174 Diagnostic help here you go - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 09-18-2008, 11:35 AM   #1
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
P0171 & P0174 Diagnostic help here you go
1. Check additive and multiplicative values
2. Perform smoke test of intake using inert smoke
3. Check Crankcase pressure with Manometer
4. Use a VE calc(volumetric efficiency calc) I posted how to do this and the file a while ago don't remember when. This will check the Maf
5. Don't forget internal vacuum leaks from purge valves or oil dipstick tube.
6. Repair the problem clear additive and multiplicative faults. Then drive the car and monitor values to see if they remain within specs.
if they do car is fixed
VE calc can be downloaded here
http://www.thompsonautolabs.com/toolbox
Build a smoke machine for testing
http://forum.e46fanatics.com/showthr...=smoke+machine
NOW QUITE REPLACING RANDOM PARTS AND START DIAGNOSING ISSUES
IF I SEE ONE MORE I HAVE THIS CODE WHAT SHOULD I REPLACE?? I AM GONNA.........................
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 09-18-2008, 01:29 PM   #2
jbeurotech
Regional Sponsor
Since there is already a post since I made this I give up.
Seth Thorson
Old 09-18-2008, 01:31 PM   #3
Dan99
My Ride: 2001 330xi
cool I've always wanted to make a smoke machine, but what's the 12 volt glow thingy and where can I find one?
Dan99 is offline   Reply With Quote
Old 09-18-2008, 01:53 PM   #4
jbeurotech
Regional Sponsor
Glow plug out of any diesel
Seth Thorson
Old 09-18-2008, 02:03 PM   #5
jbeurotech
Regional Sponsor
Another side note do you guys want these types of posts or not I don't want to waste my time if no one is going to read or use this info
Seth Thorson
Old 09-18-2008, 02:28 PM   #6
TheBirdmanJD
My Ride: 2000 BMW 328Ci
Please continue...I think there's just as many, if not more people who appreciate it than those who don't have, nor will ever get a clue...
Bird
TheBirdmanJD is offline   Reply With Quote
Old 09-18-2008, 02:31 PM   #7
black323i1981
My Ride: 2000 BMW 323i Sedan
Send a message via MSN to black323i1981
do you use the smoke machine with the car running or not please let me know in more detail what to do.
thanks jbeurotech
2000 BMW 323I
Cold air intake
Optima red top
18" chromes
P46 with 6000k HID and 30 led angels (pictures coming soon)
6000k HID Fogs
Magnaflow exhaust 2nd resonator delete
Poly bushings all around
Cold air intake
Sport seats
Sport suspension
JVC KD-NX5000 DVD GPS single din
7" screen replaced sunglass holder and ashtray
12" Rockford P3
Eclipse 7122 mono class D amp
black323i1981 is offline   Reply With Quote
Old 09-18-2008, 02:35 PM   #8
jbeurotech
Regional Sponsor
Smoke machine without the car running with the intake sealed.
Seth Thorson
Old 09-18-2008, 02:45 PM   #9
black323i1981
ok perfect thank you very much ill try and build it up this weekend
2000 BMW 323I
Cold air intake
Optima red top
18" chromes
6000k HID Fogs
Cold air intake
Sport seats
Sport suspension
12" Rockford P3
Old 09-19-2008, 08:46 AM   #10
jbeurotech
Regional Sponsor
Good luck you should be able to build it very cheaply
Seth Thorson
Old 09-19-2008, 09:52 AM   #11
nathancarter
My Ride: 02 330i
While this is useful information and probably the "correct" way for an experienced tech to diagnose problems, it's probably much too advanced for most of the forum members. Remember, not everyone springs fully-formed from Zeus's head with a thorough knowledge of diagnostic procedures, or even the terminology associated with it.
Think like the average forum n00b: "I open up this post and the first line says something about additive and multiplicative values!! I got a D in high school algebra, wtf! And what the hell is a manometer!"
On the other hand, any monkey with a wrench (well, almost) can disassemble the intake enough to find out whether the lower boot is torn (which is a common cause of these particular codes). "Look for a hole in this part right here" is a much simpler concept than "perform volumetric efficiency calculations."
Not to slight your information, but it's probably useful to a very small percentage of forum readers, and therefore won't stop the deluge of threads asking about these problems.
I disagree. This is the internet, after all.
nathancarter is offline   Reply With Quote
Old 09-19-2008, 10:00 AM   #12
Brandond11
My Ride: 2002 M3
Send a message via AIM to Brandond11 Send a message via Yahoo to Brandond11
I built this last night, worked great to help me find a leak in a couple of my vacuum hoses!! Thanks jbeurotech! Now I just have to fix those hoses....
Brandond11 is offline   Reply With Quote
Old 09-19-2008, 10:00 AM   #13
ken@bimmertools
Is NOT A Mechanic
ken@bimmertools's Avatar
My Ride: F30
Hey Seth - Your efforts are greatly appreciated. So much so that I've been working on a safe and affordable smoke tester like you've posted. I've built a couple manually-operated prototypes using different smoke sources. I'm getting closer.
There seems to be a need for a cheap, easy to use smoke tester.
In the interim, I highly recommend using Seth's design and suggestions.
Ken
Bimmertools is under new ownership! Please welcome Taylor@bimmertools.com.
Click Here to say hi.
ken@bimmertools is offline   Reply With Quote
Old 09-19-2008, 10:05 AM   #14
jbeurotech
Regional Sponsor
It takes alot longer to take apart and intake then to do a proper diagnostic
Thats fine BUT there is a right way to diagnose cars and then there is the idiot way KEEP REPLACING PARTS TILL IT GOES AWAY LOL thats pretty stupid!!
Seth Thorson
Old 09-22-2008, 07:24 AM   #15
jbeurotech
Regional Sponsor
Bump for thsoe who just posted the same question about 02 sensors this applys to those codes as well
Seth Thorson
Old 10-01-2008, 12:17 PM   #16
jayton
My Ride: 01 325i
jbeurotech:
I am one of the ones that finds your post extremely helpful. I agree 100% that you should not simply replace parts until the problem is gone. That's what dealerships and many auto repair shops do.
I am a DIY type person, and I have worked on many Fords, GMs, and Hondas. When I first got my BMW, I started noticing on the BMW forums that anytime someone posts a problem, all of the replies are people that tell you how much they spent at the dealer to have the same problem fixed, and no one posts how to do it yourself.
I really appreciate your info. You are like Dr. House except for cars.
Now I am off to get started building a smoke machine to figure out my P0171 and P0174 problem. I will post back with my results.
No longer own 2001 BMW 325i Sedan
jayton is offline   Reply With Quote
Old 10-01-2008, 08:43 PM   #17
jbeurotech
Regional Sponsor
Gl that machine works as well as wjhat we use at the shop just doesn't have evap features and the durabilty we have but for a DIY it works well. Gl with your quest if you need any help just ask
Seth Thorson
Old 10-01-2008, 09:39 PM   #18
Racinghart
My Ride: 03 330i ZHP
Send a message via AIM to Racinghart
Thanks for the info man, had this code last month and found it was a leaking intake boot.
- Bruce
Racinghart is offline   Reply With Quote
Old 10-03-2008, 12:48 PM   #19
tony325ci_51
My Ride: BMW 335i 2007 Coupe
Subscribed.
Many thanks for all your useful info Seth, please don't stop, it's one of the reasons e46f is such a useful place.
tony325ci_51 is offline   Reply With Quote
Old 12-08-2008, 07:39 AM   #20
jbeurotech
Regional Sponsor
Top people keep posting the same question
Seth Thorson
ccv leak, p0171, p0174
