Sponsored by BimmerWorld
Old 09-19-2008, 12:18 AM   #1
I8URLS1
My Ride: 323i
M3 brakes on non m?
What is required in this swap? Is it just the calipers and carriers? Thanks in advance.
Asking because I know a guy with an M3 who's going to move up to a big brake kit and I want to buy his brakes.
I8URLS1 is offline   Reply With Quote
Old 09-19-2008, 12:59 AM   #2
keith_m3-4
My Ride: 02 325iT
From what I read, also rotors and pads.. then you'll need to get the carriers machined for the correct offset for clearance.
02 Steel Gray VF ZSP 325iT
keith_m3-4 is offline   Reply With Quote
Old 09-19-2008, 09:13 AM   #3
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
^ that is correct, the carriers will need to be milled.
Also be careful in the rear, there are a few more parts to swap if you want your ebrake to work Not exactly sure what parts these are on an M3 swap, as most people just do the 330 upgrade.
-Brendan
Old 09-19-2008, 11:36 AM   #4
I8URLS1
My Ride: 323i
I just was going to do the fronts if I did it. Even with 19''s I'll have clearance issues?
Old 09-19-2008, 11:41 AM   #5
keith_m3-4
My Ride: 02 325iT
Just use the M3 wheels are a reference.. stock are 18's and I believe some people run 17's in the winter. Your 19's should not be an issue unless they are odd.
Old 09-19-2008, 11:54 AM   #6
simsima325
simsima325's Avatar
its not a clearance issue with the wheel. its the carrier which is a separate piece from the caliper.
-Brendan
Old 09-19-2008, 12:02 PM   #7
AMG-ETR
My Ride: S54B32 On Boost
Send a message via MSN to AMG-ETR
never seen a pic of your car before. sick OG look!
AMG-ETR is offline   Reply With Quote
Old 09-19-2008, 12:04 PM   #8
simsima325
simsima325's Avatar
thx, its super poor tho
-Brendan
Old 09-19-2008, 12:07 PM   #9
keith_m3-4
My Ride: 02 325iT
If you referring to the milling of the carrier, I think you meant, clearance between the rotor and caliper.
Old 09-20-2008, 11:34 PM   #10
AL330CI
My Ride: 330Ci
I'm not familar with the M3 rotors. If they are the same as the BMW Motorsport rotors, then that means they are a few milimeters thicker than the non-M rotors. You need new carriers/brakets to relocate the rotor centerline to match the thicker M rotors.
AL330CI is offline   Reply With Quote
Old 09-30-2008, 07:06 PM   #11
Vinnie Vega
My Ride: 0032870Vette70Velle
whats the 330 upgrade?
Vinnie Vega is offline   Reply With Quote
