Thread Tools Search this Thread Rating: Thread Rating: 23 votes, 4.96 average. Display Modes
Old 01-20-2012, 09:29 PM   #41
StanceWerkes
My Ride: TiAg 325i
Does anyone know how to install angel eyes on a prefacelift sedan?
StanceWerkes is offline   Reply With Quote
Old 01-21-2012, 03:33 PM   #42
sillieidiot
My Ride: '06 AW 330ci
It's the same as doing any other car, except fl coupes.
Old 03-17-2012, 11:57 AM   #43
Ivanhoe
My Ride: BMW 330 xi 2005
Thanks Sillie, very helpful,
One start to flicker and do the swap, lets see what happends, thanks again
Ivanhoe is offline   Reply With Quote
Old 04-02-2012, 08:55 AM   #44
djnekkon
My Ride: MB3ci & z33 HR
Very helpful sillie. I just did mine for the sake of putting a new color to it, but I rather stick with oems. It took less than 20 minutes to do both. The soft cover is a pain to put it back on, but I used a flat screwdriver to snap the bottom then the top.
Old 05-01-2012, 08:13 PM   #45
jizzzoe
My Ride: is no longer E46 :(
Send a message via Yahoo to jizzzoe
Originally Posted by e4603 View Post
For the passenger side, moving the windshield washer reservoir slightly out of the way makes the job much easier. Just 1 10mm bolt.
^This. Made it super easy. 5 minutes driver side, 10 minutes passenger, and I'm not very good at figuring stuff out the first time! Thanks sillie!
My Steel Gray '03 330Ci... I miss you, baby!
MODS: Purely aesthetic… Shadowlined, Smoked and LED'd out!
jizzzoe is offline   Reply With Quote
Old 10-24-2012, 02:54 PM   #46
The16vReaper
My Ride: E46 330Ci Sport
Do you need to disconnect any fuses or the battery? I got told to do so but if the key is out the ignition there wouldn't be a current right?
The16vReaper is offline   Reply With Quote
Old 10-24-2012, 02:57 PM   #47
mjn77
My Ride: 330D Sport
No fuses need to be removed, just make sure your lights are turned off.
2004 330D Sport in Estoril Blue
mjn77 is offline   Reply With Quote
Old 10-24-2012, 03:03 PM   #48
The16vReaper
Thanks mate ***55357;***56397;
Old 10-24-2012, 03:04 PM   #49
The16vReaper
Ok what happened there. Lol thanks.
Old 03-07-2013, 03:26 AM   #50
Hamoudeh430
My Ride: 2005 325CI
If my 2005 doesn't have factory xenon bulbs, how hard would it be to install them? I've installed HID's on my Benz before but what made me concerned here is the bulbs you have are way smaller than the after market HID's, would they fit fine? or is it gonna be more complicated to do so?
Great video! Never got to look under my hood cayse I live in WASHINGTON!! It never stops raining and I don't have a garage
2005 325CI
2001 CLK430
2003 325I
2007 Honda Civic EX
2002 Ford Mustang GT
Hamoudeh430 is offline   Reply With Quote
Old 03-07-2013, 05:27 AM   #51
sillieidiot
it would be a lot harder. the halogen bulbs are held on by a metal clip. taking it out will be easy, but putting the bulb back in and into the correct position and then clicking the clip back in will be a chore. the halogen bulb will be even smaller than the xenon bulb in my video lol but if you have small hands, then i think you will have a better chance of doing it.
Old 03-07-2013, 05:34 AM   #52
Hamoudeh430
My Ride: 2005 325CI
Thanks man! Ill look into it and see what I can do about it.
2005 325CI
2001 CLK430
2003 325I
2007 Honda Civic EX
Old 07-04-2013, 03:20 PM   #53
TotheMountains!
My Ride: 2001 330xi
Thanks for the great write-up. Reading all of the posts, and seeing how tight it is in there, I am very happy that my 2001 330xi has the rubber dust cover/seals rather than the rigid plastic you show. There would have been a whole lot more disassembly with the plastic covers.
Now, I've swapped bulbs side-for-side -- let's see if that's my problem.
TotheMountains! is offline   Reply With Quote
Old 12-29-2013, 02:39 PM   #54
001
My Ride: 01 330ci
Thanks for this DIY.. Like the previous poster, my 2001 330ci has rubber covers so I just had to pinch it and pull it off. Replaced both bulbs, and there is a huge difference in output! Only thing is when I had the car against a wall I noticed that there is a slight yellowness at the cut off, im assuming burnt projector bowls. oh well. But thanks again for this!
001 is offline   Reply With Quote
Old 12-29-2013, 05:56 PM   #55
sillieidiot
yeah, this diy was mainly geared towards the 02+ cars. but it was the same process for all the rest.
Anyhow, glad it was able to help you. The yellow on the cutoff is normal. The burnt bowls only happen with ZKW headlights (you should have AL/Bosch single xenons).
Old 02-12-2014, 11:19 PM   #56
Brown Bear
My Ride: C320
Quick question. What are the numbers on the back of the ignition unit that connects to the D2S?
Mine both have different digits. And I replaced the bulb on one with the lower digits and the bulb did not come on but blew instantly as the small ball type thing in the bulb was grey, the inside of the innovation connector was burnt from the previous bulb that when but I cleaned it out. Any ideas on this also? Thank you
Brown Bear is offline   Reply With Quote
Old 04-13-2014, 08:12 AM   #57
MarkY
My Ride: 2001 330Ci
sillieidiot, thanks for putting this together. Super simple process with all of the pictures and detail you provided.
2001 330Ci, GruppeM, BBS RS-GT
MarkY is offline   Reply With Quote
Old 04-14-2014, 03:12 PM   #58
stalensnuitje
My Ride: '05 BMW 320D Tourin
Same here, I put in 2 new Philips Colourmatch bulbs and immediately replaced my city light bulbs (EU car ;-)) with SMD LEDs :-)
Super simple process, thanks for your guide!
stalensnuitje is offline   Reply With Quote
Old 05-10-2014, 07:53 PM   #59
Kayss
My Ride: Bmw 328i 1999
Wish my phone hadn't been dead when I needed this at the store parking lot. Guess tomorrow. Its the same thing for the xenon projector retrofits?
Kayss is offline   Reply With Quote
Old 05-11-2014, 06:46 PM   #60
sillieidiot
depends on the projector used. some projectors use a clip. but if you have the factory xenon then it should be the same.
bulbs, changing bulbs, replace xenon, swapping bulbs, xenon bulbs
