Old 09-22-2008, 08:02 PM   #1
Hellrot15
My Ride: '01 330i
MT & Rear Diff fluid change
Hey everyone
I just purchased my first Bimmer. '01 330i with a little over 100k on it.
I want to change out the Transmission and rear differential oil and I thought that I would check in to see what the preffered brand is.
Thanks for the info
Hellrot15 is offline   Reply With Quote
Old 09-22-2008, 10:04 PM   #2
dfjaws
My Ride: '07 335i / '02 Z3
I'd say Redline gear oil... I think 75W90 is pretty much the standard. Redline makes an excellent product.
dfjaws is offline   Reply With Quote
Old 09-23-2008, 04:56 PM   #3
Ricey
My Ride: 318ci
Do you use the same oil for both? Also how many litres for each?
Ricey is offline   Reply With Quote
Old 02-24-2010, 01:40 PM   #4
hosickjg
My Ride: 323 CI
I used Royal Purple fluids and have had no problems. I used RP SyncoMax for the transmission and 70W90 for the rear end. Its fairly easy to do.
hosickjg is offline   Reply With Quote
Old 02-24-2010, 04:24 PM   #5
AlphaVortex
My Ride: jalopy!
Here in Utah where it cylces between pretty damn hot and pretty damn cold, the best I've found so far for all year round was the Royal Purple fluids as well. Seems to give me the best balance.
AlphaVortex is offline   Reply With Quote
Old 02-24-2010, 10:31 PM   #6
John in VA
My Ride: '00 Farngrün 328i
The diff holds just under 1 quart. I used Red Line 75W90 GL-5 Gear Oil.
http://www.redlineoil.com/product.aspx?pid=133&pcid=4
John in VA
'03 530i
'00 328i
'86 535i
'85 535i
'85 325e - RIP
'74 2002tii
John in VA is offline   Reply With Quote
Old 02-24-2010, 10:57 PM   #7
Redlined
My Ride: 330ci
Congrats on the new car. I recently changed out my transmission and differential fluids with Redline. I used Redline 75W90 in the diff and Redline MTL in the transmission (I have a 5 speed manual). I was very impressed with the improvement in shifting smoothness after the transmission fluid change (I replaced the original fluid at 94k miles). Some people run the ATF in their manual transmissions. I don't like the idea, but you can do it and it gives you smoother shifts in the cold, because it is not as thick. Mine is pretty notchy in cold weather.
Anyways, if you are going to do it yourself, make sure you invest in a cheap marine pump that will scew onto the bottle of fluid. One nice thing about the Royal Purple stuff is that it comes in squeeze bottles so it doesn't necessarily require a pump, but I don't have any personal experience with RP. Enjoy the car!
Redlined is offline   Reply With Quote
Old 02-25-2010, 12:13 PM   #8
markusmarkus
My Ride: 2001 330Ci
H**L no! The diff gets Redline 75W-90 GL5 (gear lube formulation 5), but the box gets Redline MTL (manual tranny lube) GL4. If you put GL% in the box the box will be hard to shift - GL5 is tooo slick and the syncros won't work. If you put GL4 in the diff you'll be buying a new diff!!!
BTW, the box takes 1.6 qts of MTL, and the diff takes 1qt exactly of 75W-90.
Old 02-25-2010, 12:24 PM   #9
buddy325i
My Ride: 2002 325i
I've read in the forums that Redline performs well within the first 10K miles but starts to get notchy after that for their trannies.
I would stick with OEM. You can actually purchase a container and have your local dealer sell what is needed. I paid like $100 bucks for both OEM transmisson and differential fluids.
buddy325i is offline   Reply With Quote
Old 02-26-2010, 04:32 PM   #10
havnfun328
My Ride: 99 328i Stock
I used Redline and have been very happy with it. You are right about the diff oil. The MT actually takes D4 ATF. Go to the Redline website and they list what you need, or call them.
2003 E39 M5 Lemans Blue: The most amazing car ever built
1999 E46 328i Bone stock 5-speed: Soon to be track rat
235K and still running strong
havnfun328 is offline   Reply With Quote
Old 01-31-2012, 01:06 PM   #11
Paul325Ci
My Ride: 2002 325Ci Silver
Send a message via ICQ to Paul325Ci
Despite ATF being Redline's website recomendation, most e46 owners, myself included, have been using Redline MTL with no adverse effects. Changed around 30,000 miles until 90,000.
At around 90,000 miles, I made the mistake of allowing the manual transmission fluid to be changed out from Redline MTL to a Valvoline oil (forget the exact name/viscosity), immediately shifts are noticeably notchier, and difficult when cold - HUGE MISTAKE!! Will switch back to Redline MTL ASAP.
Hope this prevents someone from making a similar mistake.
Last edited by Paul325Ci; 01-31-2012 at 01:30 PM. Reason: too numerous to list :oO
Paul325Ci is offline   Reply With Quote
Old 02-01-2012, 11:03 AM   #12
hummer
My Ride: 2001 330CI
Love my Redline MTL in the tranny and 75-90 in the diff. It does not go bad in 10K and D4 is inferior to MTL as a manual lube! Lots of internet BS here!
