Old 09-23-2008, 10:15 AM   #1
lilbusa600
Donkey Kong Racing
lilbusa600's Avatar
My Ride: needs a new heart
Send a message via Yahoo to lilbusa600
Clutch related question
I've had an issue with my clutch where it feels like it is not getting enough fluid. It used to feel worse until I got a SS clutch line, but now it is manageable. I was wondering if anyone has any ideas as to what it can be, because in my opinion it is too easy to burn the clutch. I thought that it may have been due to a CDV, but when I looked down there I never saw one. Thanks in advance.
UUC Lightweight Flywheel, UUC SSK & DSSR, UUC Anti-Swaybars, and Supersport Coilovers + ME = Fun FTMFW!!!
Euro-Spec front and rear M3 bumpers
Myspace
Facebook
Cardomain
lilbusa600 is offline   Reply With Quote
Old 09-24-2008, 01:14 AM   #2
AntB
My Ride: MTA :(
Did this problem happen right after installation or did it gradually get worse? Add more conditions.
** Tim330i waz hur **
AntB is offline   Reply With Quote
Old 09-24-2008, 04:37 AM   #3
lilbusa600
Donkey Kong Racing
lilbusa600's Avatar
Well, it always felt like that with the oem clutch and flywheel. Let's hypothetically say that I rev the engine between 2,000 - 3,000 rpms, and come completely off of the clutch. What happens next is the clutch will make a noise similar to a straight cut gear transmission slowing down rapidly, followed by the smell of burnt clutch.
When I got my UUC lightweight flywheel and clutch combo the problem was even more apparent, but worse. During normal driving and normal engagement the clutch always felt like it was slipping. So I took it to an Indy mechanic three days after the install, and he said that my clutch is worn out and needs to be replace. I told him it must be something else because the clutch is brand new. A friend told me to get a Stainless Steel clutch line, which I did and it helped dramatically. Now, it engages just like and still gives me the same original issues that the oem clutch and flywheel did.
One last example is: If I'm on an incline hill and give it a little more gas than normal (not much just a 2-300 more rpms) then the clutch feels like it is slipping and makes the noise I mentioned previously.
Myspace
Facebook
Cardomain
Old 09-25-2008, 02:14 AM   #4
lilbusa600
Donkey Kong Racing
lilbusa600's Avatar
Post number 3 in this thread, http://forum.e46fanatics.com/showthread.php?t=609776 , is an accurate description of how I feel.
Myspace
Facebook
Cardomain
