Thread Tools Search this Thread Rating: Thread Rating: 58 votes, 5.00 average. Display Modes
Old 02-22-2009, 08:45 PM   #21
Autobot325i
My Ride: 2003 325i E46
Send a message via AIM to Autobot325i
Damn...I was rotating tires today and one front lug driver side was not going in straight. guess I will be doing this soon. since only one side is damaged should I just reaplce that one side or should i do both at the same time...what do you guys suggest.
***NEW UPDATE***
1985 318i E30
Autobot325i is offline   Reply With Quote
Old 02-28-2009, 03:41 PM   #22
Lbert
My Ride: 325i
A lug nut not going straight is not necessarily a problem with the wheel bearing. You likely may need a replacement of the wheel hub.
Although is a good a idea to replace both bearings of an axle as a pair, it is not necessary to do both.
Lbert is offline   Reply With Quote
Old 08-25-2009, 12:00 AM   #23
yogi799
My Ride: 99 328i auto
Correct me if I'm wrong here - wheel hub = wheel bearing (referring to front). Wheel hub contains the bearing inside of it. Or are they separate parts???
I've done bearings on the old Mazda 626 and they were just small circles that fit in the palm of your hand... Here it all looks like it's the hub we're replacing, with bearings in it?
Please set the record straight. Thanks
EDIT: Well, I've just confirmed it... damn... Cheapest hub I found on ebay is like 70 bucks each... Aouch.... Those small bearings for my Mazda were like 10 bucks...
yogi799 is offline   Reply With Quote
Old 08-26-2009, 02:21 AM   #24
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
I think it only comes as a hub/bearing assembly
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
bigjae1976 is online now   Reply With Quote
Old 08-26-2009, 08:56 AM   #25
plmskier
My Ride: 2002 325XI
I printed this off...went to do my front right wheel bearing on my E46 325XI and these are not exactally the correct directions on my car. Just wanted to let others know. I had a 12 pt #36 socket to remove the nut.
plmskier is offline   Reply With Quote
Old 08-26-2009, 03:53 PM   #26
GDA
My Ride: M5, 325i and 330i
Yep. Your car is not the rear drive version with simple front spindles.
Post up your DIY on the 4wd version to help the next guy.
GDA is offline   Reply With Quote
Old 11-02-2009, 11:58 AM   #27
n2Bimmer
My Ride: Loves Corners
A few tips for future DIYers, I had to do mine again this past weekend. To remove the wheel bearing after you have removed the main nut simply put the rotor back on the hub and put back 2 or 3 of the wheel bolts back on and pull it. The bearing/hub will come out, carefull not to fall on your back. After this the inner race will still be on the spindle. I used a Dremel and made a cut/line after that i used a hammer and a screw driver, one smack to the cut and the race poped out. THANK YOU GDA.
Old 11-14-2009, 03:07 PM   #28
RicardoGomezH
My Ride: 2004 330ci ZHP
Just the DIY i was looking for. I've been trying to get rid of this damn noise and i think this is the answer.
I have changed brakes and rotors
I have changed lower control arm bushings
Using the DYIs posted in this site i have saved about $400 dollars average on each of those jobs, and i had never worked on a car before. Now i love doing things myself.
Has anyone quoted how much it would cost to get these bearings replaced at a normal auto shop? vs how much it cost to do it yourself? Im just curious.
RicardoGomezH is offline   Reply With Quote
Old 11-14-2009, 03:17 PM   #29
thefrog1394
My Ride: e46- 1999 323i
The great thing about doing stuff yourself is that with each job you save a couple hundred dollars. So use half of that savings each time on the correct tools for the job, and after a year you have a huge tool collection. At least thats been my philosophy.
Photo in Cleveland, Ohio
1999 323i - Totaled at 265,000 miles.
Now an e30 & e90 owner.
thefrog1394 is offline   Reply With Quote
Old 11-14-2009, 03:19 PM   #30
inlinesicks
My Ride: E46, Jeep, Subaru
I already replaced one wheel bearing at 75k miles and now it sounds like I've got another one going out at 85k, have any of you heard of them failing at such low mileage?
inlinesicks is offline   Reply With Quote
Old 11-14-2009, 05:13 PM   #31
GDA
Man it seems like forever since I wrote up this DIY... this was one of the very first repair jobs after I got project E46.
Anyway, to answer your question - yes, depending on driving conditions, wheels and tires used and alignment conditions wheel bearings can last as little as 20k miles to sometimes over 150k. Usually they start to show some runout causing minor vibes between 50 and 75mph at around 80 to 120k miles. After they are really worn they start to groan and howl or grumble at low speeds. YMMV
Old 11-15-2009, 10:55 PM   #32
genuity
My Ride: 2001 330iS
I was wondering, can a low rumbling noise under 35 mph be the sign of bad wheel bearings? All wheels pass the wheel bearing test (rocking it from top to bottom--there is really no freeplay) though, but the noise is quite abnormal I would say, at least other non-BMWs do not make it. I do suspect the rear driver bearing, since driving like an S, I hears noise then it goes away once pressure is put on the it when I swerve right. The vehicle was also in a fender bender on that rear passenger side--this was before my ownership of it, but one can tell by looking at the repair job on it and the edges of the fender--you can see a sanding pattern.
genuity is offline   Reply With Quote
Old 11-21-2009, 11:05 PM   #33
steve.325i
My Ride: 2003 325i
GDA, thank you for the DIY. My 325i is the proud owner of two new front hubs
steve.325i is offline   Reply With Quote
Old 11-23-2009, 01:47 PM   #34
radioactiveman
My Ride: 2003 530i
Awesome write-up! I will be doing this in the next few weeks.
My question:
I see that you you have to remove the old inner race....do you have to buy a new one or is there one already on the new hub/bearing?
Thanks!
Brian
2003 530i
2001 325i Sedan (SOLD)
radioactiveman is offline   Reply With Quote
Old 11-23-2009, 02:27 PM   #35
steve.325i
My Ride: 2003 325i
My question:
Thanks!
The new hub comes with a new inner raceway.
I do recommend a new one of these which is not included. $6.50 each @ my bmw dealer ...
Dust Protection Collar p/n 31206777788
Old 01-14-2010, 11:05 PM   #36
genuity
My Ride: 2001 330iS
Greg, thanks for the DIY. I'll need to do this in the very near future. Still waiting on other parts for my project but doing my homework now ahead of time. I am hearing grumbling noises between 10 mph and 30 mph. It is the loudest at 20 mph.
Quick question--did you apply any grease to the axle before sliding in the hub? I had to replace the rotors on my truck and I had to take the bearings out and re-grease them since I notice that it was originally with grease. This is the second DIY for front wheel bearings I have seen that do not pack grease before putting in the hub. Do BMWs not require it? Do you see grease already packed in the new hub?
Also, did you do your rear wheel bearings too?
Old 01-14-2010, 11:40 PM   #37
330inthe330
My Ride: TiAg 330cic
Looks like an awesome write up. I'll be doing this soon, and this thread will come in handy!
330inthe330 is offline   Reply With Quote
Old 01-15-2010, 01:29 AM   #38
n2Bimmer
I have not used greese to put the race/bearing back on. Thats a good question, You really dont need it.
Old 01-15-2010, 10:47 AM   #39
GDA
Hello. I simply cleaned the spindle with WD 40 and then installed the new bearing. No need to use any grease.
Actually, yes, I did do the rear wheel bearings after I did the 330 front/rear brake swap. There was already a pretty good write-up on here from another member so I decided not to do a E46 write-up. That said, it was very similar to my write-up I did for my E34 M5 on bimmerforums.
PM me if you have questions to keep this thread focused on the front bearing.
And congrats to all the posters who have performed this work on their BMWs.
Old 02-06-2010, 01:02 PM   #40
eric56
My Ride: 2000 model 323i
Excellent photos and instructions. Will be doing the same soon, much more confident after seeing your work.
Thanks! EC
eric56 is offline   Reply With Quote
front wheel bearing
