E46 front wheel bearing DIY - Page 4 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 58 votes, 5.00 average. Display Modes
Old 09-02-2010, 02:22 PM   #61
pish180
My Ride: 02' M3
Send a message via AIM to pish180
For everyone else....
On my 02 M3.
I used a 1 13/16 (46.0375mm) socket that I got from Sears. Only place that had a socket that large that I could get same day. My install was flawless. My whole wheel hub came out with a simple tug and the inner race was still attached. So i got lucky I guess. I had 142k miles on my car and it was most certainly past due for front wheel bearing. I used a 4ft 1/2 drive breaker bar which work flawless for breaking the nut loose.
This was i'd say a 3-4/10 job hardness. 1 being rotating your tires. 10 being motor swap. I thought it was easy and it was my 1st time ever doing wheel bearings. Took me total pull it to pull out 3hrs. As long as you have the right tools its cake.
pish180 is offline   Reply With Quote
Old 10-03-2010, 06:33 PM   #62
ShaunWerkz
My Ride: 02 325i
Just finished doing this with my 02 325i!! Super easy with the help of this writeup! THANKS
ShaunWerkz is offline   Reply With Quote
Old 10-05-2010, 02:51 PM   #63
Bustedwheel
My Ride: 99 323i
Is the Slide hammer bearing remover really necessary? I've seen a few write ups, and sometimes they use them and sometimes not. I figure that the puller to remove the race is a necessity, but if the bearing is really worn out, won't it come right off without the slide hammer?
Also, if I pull my wheel off, will I be able to feel the play in the bearing with the rotor and caliper still on?
Need to do mine soon, and trying to line up the right tools.
Bustedwheel is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-06-2010, 02:58 PM   #64
cschlaff
My Ride: 06' 330 Cic
Where did you purchase the hub/bearing assembly? Autohausaz seems to only have the bearing itself. Linky
Any other good OEM sources?
Thanks,
Chuck
cschlaff is offline   Reply With Quote
Old 10-06-2010, 03:03 PM   #65
genuity
My Ride: 2001 330iS
Thanks,
Chuck
You need to get the part number for #1 and use that to search on autohausaz. #1 contains the wheel bearing. There is no just replacing the bearing without the hub on this one. I'd also get the other parts, since some of those are one time use and also you'll most likely damage them in the process of taking them off. AutohausAZ is a good place to get them from--I got all of those from them.
genuity is offline   Reply With Quote
Old 10-06-2010, 03:10 PM   #66
genuity
My Ride: 2001 330iS
Slide hammer will help a great deal or if you have a three jaw gear puller, it will also do the job. You might get left with the race on the axle sub. One of mine came off cleanly with the hub and the other one got stuck. Glad I got the gear puller.
You will be able to feel the play in your bearing with the rotor and caliper on, if it is that bad. On mine I did not have the play or a noise like in the videos below, but I could tell that the bearings were getting dried out and on their way out soon.
Example of noise...although this is one type of behavior displayed failing wheel bearings. There are a few other types so beware:
BimmersGarage DIYs:
Old 11-09-2010, 09:49 PM   #67
msuka
My Ride: 2013 335i M sport
Can anyone tell me if the wheel bearing nut is reverse thread like a fan blade nut or is it normal thread, thanks.
msuka is offline   Reply With Quote
Old 11-09-2010, 10:08 PM   #68
pish180
My Ride: 02' M3
pretty sure its normal threaded.
I actually found it quite easy to break it lose. Just get a long pipe and use at least a 1/2" drive if not a 3/4" drive. Mine where almost effortless and I have 144k miles from the DC area (aka we get snow).
Old 11-09-2010, 10:38 PM   #69
genuity
My Ride: 2001 330iS
It's normal threaded.
Old 11-09-2010, 11:17 PM   #70
TrickTizzle
My Ride: 325i
How long did it take you to do this?
and
Whats the level of difficultY?
Also what mileage is this usually due?
Old 11-10-2010, 12:16 AM   #71
msuka
Thanks for the quick reply guys, will be replacing my driver side bearing this weekend.
Old 11-11-2010, 10:07 AM   #72
msuka
got it off this morning took me less than 2 minutes since I already had the rotor and caliper off for my brake job, no need for the jaw puller I was able to slide it off by hand.
Old 11-11-2010, 06:48 PM   #73
RP323i
My Ride: BMW 323i
ONE Question, on the issue of bad wheel bearing/hub assembly. Can a bad bearing cause one side of the car to be 5mm lower?? I think my front right bearing is shot, and for some reason that side sags 5mm lower than driver side. BTW I already replaced springs/struts, control arms/balljoints are good, and CAB's are new. I don't see anything else that could cause this imbalance, which is causing my car to pull to right. But I've never heard any1 say a bad bearing/hub assembly can cause this. And it is making noise, so I already ordered the hub assembly. I guess I will find out after the install, hopefully my wheels don't fall off until then.
RP323i is offline   Reply With Quote
Old 11-12-2010, 10:53 AM   #74
GDA
My Ride: M5, 325i and 330i
Good to see that others are getting some good use from this old DIY.
^ With regard to your height and pull issue, I would doubt that its cause is a bad wheel bearing. Consider that a wheel bearing is by design to roll in a parallel plane to the strut assembly so it would have to have a major amount of runout in it to allow for the wheel to slack such that it has dropped the ride height 5mm at the top of the tire.
Based on your repair list, I'd say it is more likely ball joints or strut mounts.
GDA is offline   Reply With Quote
Old 11-12-2010, 11:31 AM   #75
franz
My Ride: 03 330i
Snap-On has a really nice 46mm impact socket that has a 1/2" drive which would be cool to use without an adapter. Sure the socket is overpriced, but I wonder if it is small enough on the outside, it's not thin walled. I believe it's 64mm OD.
franz is offline   Reply With Quote
Old 11-12-2010, 12:04 PM   #76
BimmersGarage
My Ride: E46 330i
Hey GDA
How's it been?
Agreed, more likely strut mounts (or strut tower area) than hub bearings..
I'm curious... where are you taking the height measurements, exactly?
And, are there any non-standard "weighted" items in your vehicle? (ie: Audio amps, subs, extra batteries, etc.) That may be causing the the issue.
Also, who did the front strut/shock install... Perhaps a spring pad was left off or not set properly on one side... (Driver side?) (#8, 11)
Lastly, is the reinforcement plate (subframe brace) installed properly? At the right torque and torque angle.
(#3)
Just brainstorming some of the possibilities.
BimmersGarage is offline   Reply With Quote
Old 11-12-2010, 07:14 PM   #77
GDA
You are talking about the one I used in my DIY. Check the pic with it on my BP 1/2 impact. Lots of room, hasn't even marred the outerwall of the socket and i've also used it on my E34 M5 and some other older BMWs.
Old 11-13-2010, 09:05 PM   #78
franz
My Ride: 03 330i
So it is, thanks!
Old 11-23-2010, 11:30 AM   #79
Bustedwheel
My Ride: 99 323i
I decided that I couldn't stand the noise anymore and just ordered the parts for this. I know I might get some sh1t for this, but I ordered the hubs/bearings from Advanced Auto Parts. They were free shipping and 20% off. Total was $130. The socket was the bigger pain. I ordered one from northern tool for $10, but it is a 3/4 drive. Got an adapter for $5 to bring it down to 1/2.
If anyone is in Boston and wants to borrow the socket afterward, PM me.
Old 12-02-2010, 02:31 PM   #80
Bustedwheel
My Ride: 99 323i
I just finished replacing both my about 10 minutes ago. Took me about 4 hours total. Most of the time was spent wrestling off the inner race. A word of advice. Use a puller for the inner race. The dremel technique should be a last resort. I know harbor freight has them for pretty cheap. With the dremel, you have to cut almost all the way through the thing, being careful not to hit the spindal, and then split it with a chisel and hammer. Not fun. Had I had a puller, it probably would have taken me half the time.
Getting the old bearing off is pretty easy. I had some old rotors laying around, so I turned one backwards and bolted it to the hub to give me something to hold on to. Probably could use your regular rotors as well, as it probably won't damage them. Hopefully you have the puller and you could use it for this too, but not needed.
I also started to remove the caliper form the bracket out of habit, then realized it is unnecessary and you can just take it off all together and hang it from the spring (unless you are doing brakes at the same time)
Also, I did not remove the inner seal and the brake baking plate. I was able to clean it well enough with it on, and I didn't want to risk bending it up.
The 46 MM socket I bought worked great for tapping the new bearing back in place as well.
It sure was nice bolting everything back on to a nice clean new hub!
front wheel bearing
