Rating:
Display Modes |
#161 |
Just found it thanks to your prompt.
For reference - http://www.youtube.com/watch?feature...&v=wKYL9_4mXRI and http://www.youtube.com/watch?feature...&v=D4PK1jXhppE Cheers
![]() I can help with * Reading Codes / Coding your car * R&R FCAs, Tie Rods, Sway links.... * RTABs Need an RTAB tool? Or clutch fan and water pump tools? PM me. |
#162 |
Yep
#163 |
Hi Guys,
I have what I think is bearing noise, but it's not your typical "groan" that comes with load, like I've always experienced in the past with bearings. This sounds more like a squeal, similar to brake pads rubbing on a warped rotor. But I changed the pads, calipers, and rotors last week, so I know that is not the issue. It also doesn't change the noise at all to apply the brakes. It seems to be fairly quiet upon a cold start, and definitely gets worse as you drive. Happens in all gears and neutral, so it's not tranny related, definitely wheel related. Does this sound like it could be bearings? 2003 325i w/about 90K. Thanks, Ed. |
#164 |
90k is when my front bearings gave out. Worth a try.
#165 |
Hi Guys, thanks for this DIY I took off the old hub and inner race from front passenger side without much problem.
But I am stuck at trying to put on the new hub. It just wont go in onto thicker part of the spindle. It gets stuck at the outer edge. With a deadblow and a 36mm socket, I have been trying to knock it in on the race with moderate force already. And hub looks pretty aligned to the spindle. I got this F.A.G. hub 31-22-6-757-024-M34 from Pelican for my 2003 325Ci. Could it be a faulty part or does the hub need to be pressed in (how?)? Thanks. |
#166 | |
Good luck. |
#167 |
Finally got the new hub on. I had to push on the hub by hands really hard to get it move in by a notch. Then tapping on the race with 36mm socket worked like a charm
#168 |
Another GREAT E46 Fanatics thread... Just don't know how much I have enjoyed my Bimmer over the years knowing that if anything is wrong you guys normally always have the answer along with a nice DIY. Going to be tackling this myself Saturday.
![]() VMR710 BMW Velocity Motoring V710 18x8.5 Staggered |
#169 |
My Ride: 2003 325i
quick tip - the new hub will slide on a bit easier if you apply a small amount of grease to the spindle first.
#170 |
I applied grease to the hub and spindle just because they're mated surfaces. I thought that was in the instructions too.
![]() But yeah. It slid on pretty easily. |
#171 |
My Ride: gobbles oil like a B
My turn for this.. passenger side front wheel bearing is going, bought 46mm socket from Northern Tool for $17 shipped. Autozone has torque wrenches to loan out that go up to 250FT/Lbs with a $100 deposit that you get back when you return it.. nice! Got the SKF bearing from BMA parts as that was the best price by far on line.. almost considered the PAX until I read the ill fitment in another thread where it didn't work..
#172 |
Be careful with the autozone torque wrenches. I was almost all the way through my install, and it turned out the wrench was broken. When set to 215 lb-ft, it was clicking at maybe 50. I think it's much safer to just invest in a new one. I tried getting by with a breaker bar and a scale, and now my passenger side wheel bearing failed < 10k miles later.
This time I'm not cheaping out. I bought a split-beam torque wrench from precision instruments. Made in the USA, and they're basically the OEM for some of Snap-On's torque wrenches. Last edited by TerraPhantm; 09-14-2012 at 09:39 PM. |
#173 | |
#174 | |
And yeah, the difference between 50 and 215 is extremely noticeable - hence why I noticed. But what if the difference isn't as extreme? Would you really notice the difference between say... 180 and 215? Or what if it's miscalibrated in the other direction, and you end up overtightening it? Unless you have some way of verifying the torque wrench before using it, then I would strongly urge just buying one. For this job a beam type might actually be best. Dead-accurate and cheap. Last edited by TerraPhantm; 09-17-2012 at 09:45 AM. |
#175 | ||
I purchased F.A.G bearings front/rear when I replaced the bearings on my car. I had one of the front bearings go out after only ~5K of use. The vendor I purchased the bearings from did replace it under warranty however their site now only showed SKF listed under the manufacture for the bearings. The replacement came in a SKF box but the actual bearing had a F.A.G stamp on it and looked identical to the one I previously used. Quote:
http://www.tooltopia.com/precision-i...-c3fr250f.aspx |
#176 | |
#177 |
Very cool to see my old DIY is getting tons of mileage.... brings back good memories of the first couple major projects on the sedan.
#178 |
Quick question guys. I'm about to tackle this DIY and am getting ready to order parts.
Do the F A G hub/bearings come with a new 46mm axle nut or do you have to buy a new one separately? Thanks in advance for the info
#179 |
I had to pay extra for them to be included with mine (from Turner)
#180 |
Check harbor freight. It's just a regular big ass socket.
| Tags |
| front wheel bearing |
