Staggered v. Non-staggered - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 09-25-2008, 11:02 AM   #1
mosill
My Ride: E46 M3
Send a message via AIM to mosill
I did some research last night based on a question I had about using spacers in another thread. I thought the results were interesting enough that I would post about them in case anyone else ever wondered the same thing.
M3 come naturally with a staggered wheel set up. If you put big spacers on the front and make the tires flush all around you then have a less staggered setup.
Staggered offset cause the car to have a understeer type of handling where non-staggered give you a neutral handling.
I also pulled this from a website:
http://www.autozine.org/technical_sc...ech_index.html
"In fact, when running in straight line, we want a little bit understeer to make the car stable. When the car is subjected to side force, probably due to cross wind or the road's irregularities, understeer could resist the force and avoid the car to be steered automatically, therefore the driver need not to correct the steering frequently.
When the car is entering a corner, we also need a light understeer to provide the stability while the driver is easing off the brakes and building up cornering force. In mid corner, we need neutral steer. In the exit phase, a slight oversteer will be welcomed as it helps tightening the path."
mosill is offline   Reply With Quote
Old 09-26-2008, 04:05 AM   #2
Chris-TK
My Ride: Mk VI GTI
Si senor.
K.
Chris-TK is offline   Reply With Quote
Old 09-26-2008, 04:13 AM   #3
Rayce185
Modifiziertes ///Mitglied
Rayce185's Avatar
dun dun duuuunnnn
Rayce185 is offline   Reply With Quote
Old 09-26-2008, 07:00 AM   #4
Breyton-BMW
Breyton-BMW's Avatar
My Ride: Ti
Send a message via AIM to Breyton-BMW Send a message via Yahoo to Breyton-BMW
Thank you for posting
Breyton-BMW is offline   Reply With Quote
