Sponsored by The Tire Rack
Thread Tools Search this Thread Rating: Thread Rating: 114 votes, 5.00 average.
Old 04-18-2012, 04:48 PM   #1581
Eforthysick
My Ride: E46 soon...
Hey sup everyone.. I wanna post my car's pic sometime soon.. But still looking for tires.. Just wondering. I have the vmr v710 19x8.5 square setup.. But would like to do thicker tires in the rear if possible.. Was thinking of doing 235/35 19 front then 245/35 or 30 19 in the rear.. Can anyone give me an advise pls.. Ty..
Eforthysick is offline   Reply With Quote
Old 04-18-2012, 05:12 PM   #1582
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Ty,
I cannot guarantee that 245/35's in the rear will not have rubbing issues, but I have seen members run that set up in the past. However, since you do have a square wheel set up, you might as well just run a square tire set up so that you can rotate the wheels.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 04-18-2012, 05:19 PM   #1583
Eforthysick
Thankbyou.. Ill probably do tht.. What about using spacers to make the rear look staggered?
Old 04-18-2012, 05:43 PM   #1584
rovert
My Ride: is an Individual
Send a message via ICQ to rovert Send a message via AIM to rovert Send a message via MSN to rovert Send a message via Yahoo to rovert
--Trevor--
Vancouver, BC
rovert is offline   Reply With Quote
Old 04-18-2012, 06:21 PM   #1585
VMRWheels
VMRWheels's Avatar
^ mmmmmmmmmm... Amazing photo skills.
You could do that, but I would suggest waiting until the wheels are on the car and measuring the gap between the fender and the wheel to determine the correct size of spacer.
Old 04-18-2012, 07:24 PM   #1586
AE46fanaticlol
My Ride: looking for an E46
More I took today....VMR I will take better hi res pics this weekend and in your inbox they go! Btw I have 19x8.5 fronts and 19x9.5 rear running 225/255 tires
ID:	447193   Click image for larger version
ID:	447194   Click image for larger version
ID:	447195   Click image for larger version
ID:	447197   Click image for larger version
ID:	447198   Click image for larger version
ID:	447199   Click image for larger version
ID:	447201   Click image for larger version
Originally Posted by TurboMliner View Post
Yes, the engine runs perfectly with no problems. The motor is not damaged in any way. Just has a bit inside the head.
AE46fanaticlol is offline   Reply With Quote
Old 04-18-2012, 11:23 PM   #1587
STORMER
My Ride: AA SC 98 M3
Just got these ready to mount!
18x8.5 et 35 235/40/18
19x9.5 et45 265/35/18
Will post some pics hopefully tomorrow of them mounted when i get a chance
Stupid question??? 600 posts and I am a noob when it comes to suspension.
I ordered Tein S springs am I going to have rubbing issues? (sedan)
When I get an alignment is the camber adjustable with stock setup?(dont think so)
What should I expect when I run this setup. Any info to help a noob is appreciated
Killing time at work using BimmerApp
360+rwhp
AA Stage 2, Arp2000, Underdrive Pulley, M50 Manifold, Cat Delete, Supersprint Exhaust, M5 Clutch w/ Lightweight Flywheel, Euro Fan, FK Coilovers, AEM Boost Gauge, Zhp Knob, Stoptech Brakes, R1 Rotors
Originally Posted by Sweetness View Post
You sir, just thread jacked the sh!t out of OP.
STORMER is offline   Reply With Quote
Old 04-19-2012, 10:03 AM   #1588
AE46fanaticlol
In the front you will most definitely have rubbing...it will be a super bouncy ride.I have tein s techs- you will need to replace your factory shocks ASAP! they will blow soon if they have not already...be careful for dips in the road the rebound and compression on the front with the tein s techs and stock struts will cause rubbing for sure.- I have bilstein sports all around and it's perfect.
Old 04-19-2012, 12:56 PM   #1589
STORMER
Ok so you no longer rub with the bilstein sports? Were you able to adjust camber? Or is it not adjustable with stock setup? The reason I ask is my rear camber is already quite a bit on non sport setup, and I am worried that when I drop itll be too much? Sorry for all the noob questions, I have searched but cant seem to quite get answers I am looking for.
360+rwhp
Old 04-19-2012, 01:39 PM   #1590
AE46fanaticlol
I do not rub with the sports and its not a bad ride at all. The actual ride will be fine for your springs...just bouncy normal cruising all that good stuff...but if you wanna have a little fun drive a little hard...the faster you go the more bouncy it's gonna be and all down hill from there... look out for dips/drops while even driving normal that's where you will rub just be careful driving on the springs...save up for some new shocks/struts and you'll be good to go!
Old 04-19-2012, 03:26 PM   #1591
VMRWheels
VMRWheels's Avatar
Pictures look great! Can't wait to see those Hi-res pics.
With the 265/35/18s on the rear you may also run into a slight rubbing issue. If anything, they would need a slight roll.
Now hurry up so that we can see pictures of them mounted!
Old 04-19-2012, 04:22 PM   #1592
AE46fanaticlol
Oops I spotted a typo on my behalf....I have 18s not 19s!
Old 04-19-2012, 04:43 PM   #1593
VMRWheels
VMRWheels's Avatar
Black Sapphire Metallic E46 M3 on 19" Gunmetal V705s
Old 04-19-2012, 11:20 PM   #1594
STORMER
Just a couple quick shots for now sorry for iphone quality and car is dirty
I think it looks great!
Tein springs and Koni shocks on the way as well as mtechII bumper
Will post more pics after a proper shoot!
360+rwhp
Old 04-20-2012, 12:38 PM   #1595
STORMER
Fender roller lined up for suspension install
360+rwhp
Old 04-20-2012, 06:06 PM   #1596
VMRWheels
VMRWheels's Avatar
[IMG]http://img.tapatalk.com/ce4b6985-e408-20b9.jpg[IMG]
Definitely looks good. Love the storm trooper look. Should look great with a drop and the M-tech bumper.
Old 04-20-2012, 06:55 PM   #1597
STORMER
Thanks. A lot of people here on the forum feel black rims are played out but I say no!!! Love it
360+rwhp
Old 04-20-2012, 09:07 PM   #1598
Evap
My Ride: rubs tires
I personally dislike black wheels for one reason: when I've taken friends who know nothing about cars to shows and they see most black wheels, they've asked me why they're missing their hubcaps. Kinda awkward haha.
BimmerApp wut
Evap is offline   Reply With Quote
Old 04-23-2012, 12:41 AM   #1599
djtrini
My Ride: 04 M3 & 05 330i ZHP
For a 2005 330i ZHP Sedan what would be an aggressive set up in 18" VB3's or possibly 710's?? Tires i'd be using are Yokohama S.Drives Front 225/40/18, Rear 255/35/18.
Car is slammed on KW v.2's
Here's a pic for reference of the ride height I keep the car at:
Name:	Tasha car 2012.jpg
djtrini is offline   Reply With Quote
Old 04-23-2012, 02:16 PM   #1600
NightRaider93
My Ride: 2007 Z4 Coupe
I was thinking about getting some VB3's or V710's but I don't know how they would look with just a facelift bumper. I don't want it to end up looking bad. Do you guys have any pictures?
-Spencer
NightRaider93 is offline   Reply With Quote
Rate This Thread
