Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
#1 |
Engine code when AIR pump removed?/o2 simulators?
Hi all. I am planing to do some modifications to my car(2000 323ci) and was wondering if I could remove the air injection pump without throwing a engine code. Also if said code is thrown is there anything I can do to fool the system into thinking that the pump is still installed?.
On a side note. I am also thinking about relocating my catalytic converters. i would however need to relocate my secondary oxygen sensors as well. No big deal what so ever. But is there a company out there that makes O2 sensor simulators? Id rather throw those on for the time being and redo my exhaust the right way come winter. Any help would be greatly appreciated.
Born in the BG Raised all over. No wonder I'm confused.
#2 |
Banned User
My Ride: E46 330 and E30 325
Why would you remove the pump? It won't harm anything to keep it there.
And how are you going to relocate the cats? They're built into our exhaust manifolds. You mean you plan on getting racing cats and new headers? |
#3 |
Banned
Why do you want to remove the air pump?
Relocating the cats is easy, as is extending the o2 sensor wires. You might as well do it right the first time. There is no point in keeping cats at all if you arent going to use them properly. |
#4 |
Keep it clean
Come on, you guys.... removing the emissions is the way to performance. You lose like, 1 lb off the front of the car!!!
#5 |
My Ride: 03 325XI 07 ZX-6R
Someone on here told me you can ship your ECU to ESS Tuning and have them re-flash your ECU to remove "Post-Cat Efficiency" feature. I guess that's the right way. Now if there o2 simulators for sale, I'm Up for it.
|Dinan High Flow Air Box|Eibach Pro Kit|Koni Sport|UUC Strut Barbarian|UUC TSE3|UUC Underdrive Pulleys|18" VMR V710| ![]() |BMC Race Air Filter|CRG Spectrum Levers| Galfer Steel Braided Brake Lines|Volar Motorsport Spiked Frame & Bar-end Sliders| |
#6 | |
I will most likely re-locate the cats as opposed to remove them. I just wasnt sure how relocating the cats would effect their efficiency and thus the reading that the post cat sensors recieve.
#7 | |
http://www.supersprintna.com
