Forced Induction Forum Sponsored by Active Autowerke
Discuss supercharging, turbocharging and even nitrous and water injection here. Sponsored by Active Autowerke |
#1 |
BOV anyone?
Check this out!
Something a little "different". Last edited by billetboy; 09-27-2008 at 06:52 PM. |
#2 |
uhh no!
![]() -Jorge All low no go |
#3 |
My Ride: HPF Stage 2.5 e46 M3
Hu?
#4 |
#5 |
#6 |
First time ive seen something like that.
what was that on? and what kind of FI was on the car?
![]() 2010 SRT8 Challenger (mildly built motor) 2007 SRT8 Jeep Cherokee SRT8 SOLD! 2006 Subaru STI highly modified SOLD! 2003.5 E46 M3 (the smurf) SOLD! |
#7 |
My Ride: '02 325i / '07 600RR
Description: "This is one of my 3 inch valves temproarily installed on my friends 51 Chevy truck. Motor is a 4200 vortec motor with turbo sitting on one of my billet steel cnc turbo manifolds."
#8 |
The damn thing replaces a part of the charge piping like an MAF replaces charge piping. Pretty crazy. It probably works better than normal BOVs because it let's all air going back to the turbo escape (I assume because when it works it's like a piece of charge pipe falling off), rather than hoping all the air can escape through a little hole through the side of a charge pipe the way most BOVs are routed.
![]() ![]() | TRM | The Racers Market | Turbo M3 | 559whp@18psi | Dynojet Confirmed 6-1-2010 | | The Truth Shall Set You Free! | It's Good To Have Her Back! | Last edited by turboaddiction; 09-28-2008 at 09:41 PM. |
#9 | ||
#10 | |
![]() How much you charging for one of those bad boys? Sounds like there needs to be more R&D to make sure the seal is 100% secure though. Have you tested the psi on the seal? Does it beat 100psi?
![]() ![]() | TRM | The Racers Market | Turbo M3 | 559whp@18psi | Dynojet Confirmed 6-1-2010 | | The Truth Shall Set You Free! | It's Good To Have Her Back! | |
#11 | |
I tested it with an air compressor at 100 psi and nothing blew out so I figured I was past anything most people would run. As long as the are installed on a decent piece of pipe (not on a cut bend) thay seem to work fine. I've sold lots of these valves and the only thing I ever did as far as warranty was send a guy some new O rings which are 20 cents a piece. I usually sell them for $200 but to be honest I spend most of my time making the CNC'd Billet manifolds so I haven't really pushed these. I just thought you guys might get a kick out of it. |
