Old 09-28-2008, 04:22 PM   #1
e46Bermann
My Ride: 330iSC.AA.L2.5 & KTM
14 psi?
hello friends, I am quite happy with the outcome of Level 2 of C38 of AA, now blown to 10.5 psi, I understand that most of the block and components M54B30 3.0L, 400hp approx can withstand a few, now I would like to increase the Blow to 14psi, I think I just need a pulley to achieve this, I would like to know your views thanks.
AA C-38 LEVEL-II 10,5 psi boost level, and more...
e46Bermann is offline   Reply With Quote
Old 09-28-2008, 04:34 PM   #2
docwyte
My Ride: '89 944 Turbo
The C38 can't spin to that level of boost.
'98 M3, track beast
'06 Porsche Cayenne Turbo S 521hp daily driver
'07 KTM 990 Adventure
docwyte is offline   Reply With Quote
Old 09-28-2008, 04:54 PM   #3
e46Bermann
important to your opinion
Pulley diameters available 70,75,80,85,90,95,100,105,110mm
Old 09-28-2008, 04:55 PM   #4
MSpired
My Ride: HPF Stage 2.5 e46 M3
Send a message via AIM to MSpired Send a message via MSN to MSpired Send a message via Yahoo to MSpired
x2, the most I would squeeze out of the C38 is 11psi, and even that is overspinning the blower by a good amount.
MSpired is offline   Reply With Quote
Old 09-28-2008, 05:07 PM   #5
e46Bermann
That is, one can not by the technical characteristics of the C38? because that's what I'm understanding.
I read that Japanese cars will put the C30 with peaks of 14 psi, I am confused.
Old 09-28-2008, 05:10 PM   #6
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
The smallest pulley you can run on the C38 with the OEM non-m crank pulley without overspinning the blower is 80mm. That should put you at 12.XXpsi, and with supporting mods, you'll be at over 350whp.
Many japanese cars have smaller displacements, so they require less a smaller volume of air to create X amount of boost.
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 09-28-2008, 05:14 PM   #7
docwyte
The rotrex blower itself can not spin that fast, it'll blow up if you try to get it to push 14 psi. Just because the pulley exists doesn't mean you should use it in your application.
'98 M3, track beast
Old 09-28-2008, 05:26 PM   #8
e46Bermann
Thank you very much, then with 12.xx psi can reach the level that I want?, Speak with Kirk Tabera to send me the 80mm pulley, you can talk about your preparation for PM, I would like (If this is not a problem) more info or tips to me,,, again thank you very much.
Old 09-28-2008, 05:31 PM   #9
e46Bermann
OK, I understand, then thank you for your comments, greetings.
Old 09-30-2008, 04:24 AM   #10
Bimmerguy82
My Ride: 2004 ZHP 6 SPD
If you are going for gobs of HP and high boost, you are better off with a turbo setup.
BMWCCA member #407674
___________
-Joshua
ZHPMafia.com member
Ebay headers | 3.38 diff | 2.5" cat-less exhaust | K&N intake | AA stage 1 software | UUC stage 1 light flywheel and clutch | UUC Evo 3 ssk
Bimmerguy82 is offline   Reply With Quote
