Old 09-29-2008, 09:18 PM   #1
christraylor2
My Ride: 2002 325CI
325CI Heating Problem
Hey, so I have a 2002 325CI with barely 80k miles, the AC works AMAZINGLY well during the day (temps outside 80+ degrees) but in the mornings, when the temperature is around 55-60, the heat (on 91 degrees) even once the car heats up isn't hot. It worked a while back and recently, whenever I turned the heat on, the low coolant light would come on until about a minute after the heat was turned off. I filled the coolant up and this is what happened. Any ideas? Thanks guys.
christraylor2 is offline   Reply With Quote
Old 09-29-2008, 09:23 PM   #2
tradingflare
My Ride: needs a mechanic
Well...start with the basics...is the center dial between the center vents moved to the "hot" position? (Three red dots)...
Does the coolant system need to be "bled" for an air pocket/
tradingflare is offline   Reply With Quote
Old 09-29-2008, 09:35 PM   #3
christraylor2
My Ride: 2002 325CI
Yes, everything is moved to "hot". I turn off the snow symbol on my AC control and turn it all the way to 91. I'm not sure if that needs to be done or not.... That's why I posted this to see if anyone else ever had the same problem
Old 10-15-2008, 10:14 PM   #4
christraylor2
My Ride: 2002 325CI
bump
Old 10-15-2008, 10:17 PM   #5
e30m3izzle
Banned
My Ride: 1999 323i pal!
im thinking maybe some sort of coolant temperature sensor like thermostat?
e30m3izzle is offline   Reply With Quote
Old 10-15-2008, 10:24 PM   #6
christraylor2
My Ride: 2002 325CI
the thermostat was replaced brand new and that solved nothing. My car doesn't overheat so I don't really think the thermostat would be faulty...
Old 10-21-2008, 09:57 AM   #7
christraylor2
My Ride: 2002 325CI
bump. It started working randomly on the road it began to work again then cut itself off. I replaced my thermostat but traveling at highway speeds my car cools down to just above the 1/4 mark. I bled my coolant twice and seems that air keeps appearing. Could there just be that much air or is there some way air is leaking in or is my new thermostat broken as well?
Old 10-25-2008, 11:54 AM   #8
christraylor2
My Ride: 2002 325CI
bump, winter approaching quickly guys, would really appreciate some help here....
325ci, coolant, heat
