Old 10-04-2008, 12:22 PM   #1
neil1138
safe to unplug MAF?
I think my MAF is bad so is there any way to test it? Like unplugging it and driving around? Just to see if the problem is still there? Thanks.
neil1138 is offline   Reply With Quote
Old 10-04-2008, 12:25 PM   #2
jeffro3000
My Ride: 2000 328i
how will unplugging the MAF tell you if there's a problem with it or not???
will the car even run without the MAF?
jeffro3000 is offline   Reply With Quote
Old 10-04-2008, 12:27 PM   #3
issacsierra06
My Ride: bmw 325i
whats going on with ur car first of all?? my car was acting retarded last year turning off and on ended up being cam position sensor after i did some research up on here
READ BEFORE YOU BUY
issacsierra06 is offline   Reply With Quote
Old 10-04-2008, 12:30 PM   #4
neil1138
Are you serious? If I unplug the MAF, the car is going to run off some kind of safe mode or something and if my problem is gone, then I know it's the MAF. I just don't want to drop $300 on a MAF without knowing it's the problem.
I just want to know if it's safe and ok.
And I have already replaced ten things trying to find the problem. I don't want to troubleshoot here, I just want to know if it's ok to run with an unplugged MAF.
Old 10-04-2008, 12:32 PM   #5
jeffro3000
My Ride: 2000 328i
my moms e39 needed a new MAF. the symptoms were random misfires, mild loss of power, and eventually the car would not idle. if your foot was not on the gas, it would immediately die.
Old 10-04-2008, 12:33 PM   #6
jeffro3000
My Ride: 2000 328i
im 99% sure unplugging the MAF will not diagnose your problem.
What is the problem you're having??
Old 10-04-2008, 12:38 PM   #7
neil1138
Look for my past threads called "jerky acceleration at 50mph". There's my problem, I thought it was fixed after I replaced my CCV but no... This BMW is turning out to be a hellhole. I'm about to the point where I want to say fvck this car, I'm done.
I've had my Indy shop look at it, the dealer look at it, and I've thrown multiple parts at it to try and fix it. The only things I haven't replaced are my MAF, cam sensor, and O2 sensors
Old 10-04-2008, 01:18 PM   #8
Zchild
My Ride: 2000 BMW 3XXi ZSP
Cool
My question to you would be have you tried cleaning the MAF with MAF cleaner, I would suggest that before you replace the one you currently have in your vehicle. Its a real easy DIY, AutoZone or any auto parts store will have MAF cleaner fluid. Simply remove the MAF, spray it completely wait for it to air dry completely and re-install it. This should give you and indication of whether or not your MAF is a part of the problem. My only other question is how many miles you have on your vehicle? Just my two and a half cents worth. Happy Motoring...
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 10-04-2008, 01:21 PM   #9
Miko_10
My Ride: 330i 5 Spd
http://forum.e46fanatics.com/showthr...824&highlight=
Try that, the shop i took it too said that my software was out of date...
FS(PM me if interested, MID Atlantic Area, 22307 zip)
- 2 M68 fronts w/ winter tires, local pick up preferred,
- OEM Pre face Sedan Clears.
Miko_10 is offline   Reply With Quote
Old 10-04-2008, 02:29 PM   #10
elite53
My Ride: Twin Screwed 325Ci
You can start the car without the MAF pluged in and it will run fine but you can not drive it like that.
elite53 is offline   Reply With Quote
Old 10-04-2008, 02:32 PM   #11
Cobra
My Ride: '00 328i & '06 R6S
did you even try cleaning the maf with crc maf cleaner?
Cobra is offline   Reply With Quote
Old 10-04-2008, 02:57 PM   #12
neil1138
Well I just got back from walmart and I thought I would check and see if they had CRC MAF cleaner, they did not. So I finished my shopping and took the twisties back home, (twisty roads in oklahoma?, yeah there are some) and she drives like a dream! Before I left, I checked the car out, topped off my power steering fluid and checked the MAF, and somehow, the problem isnt there anymore. I just dont know guys.
The only things left that I havent replaced are the:
MAF
cam sensor
crank sensor
O2 sensors
fuel pump.
I've pretty much thrown a lot of parts at it in the past 6 months; CCV, spark plugs, fuel filter, and coil packs. I'll clean the MAF but im kinda hesitant because I've heard horror stories about how after cleaning, cars wouldnt start and so forth. IMO, if it aint broken, dont fix it. So for such an expensive thing as the MAF, somebody here really has to persuade me to clean that. Later
Old 10-04-2008, 02:59 PM   #13
neil1138
oh and to Miko 10: I already had the dealer reflash my ECU and that didnt help the problem. And I think that problem is for the ZHP's, not regular 3's.
Old 10-04-2008, 03:04 PM   #14
Eurobahn BMW
Eurobahn BMW
Eurobahn BMW's Avatar
My Ride: BMW Greensboro
Yeah, unplugging you maf will be fine. i've done it before to diagnose problems, and i've driven like that. It reverts to factory software and fuel maps and **** so i can't adapt to the current environment but it basically runs on what it thinks the environment is. Sometimes this works and sometimes it doesn't.
Eurobahn BMW MMINI Mercedes Benz Audi of Greensboro is your local independent BMW Greensboro We offer BMW dealer-level Service & expertise at a fraction of the cost at our BMW Greensboro NC dealership.
Eurobahn BMW is offline   Reply With Quote
Old 10-04-2008, 04:53 PM   #15
dave330i
My Ride: 2001 330i steel blue
I had the same problems...I found it to be my MAF, I went to aboveallmotorwerks.com and they have it for $206 shipped, I did ALOT of looking online, it is the same one as the one BMW will sell you Siemens VDO.. I have also heard rumors that the Hyundai Sonata uses the same one and it is like $155 or 185 burt I have just seen that on some threads...bimmerforums I think had a write up
2001 330i 5sp Sport package ,steel blue, AA S/C , Remus exhaust, UUC Short shifter, UUC clutch stop, Braided brake lines, UUC Strut bar, Xenons, depo clears, Eagle Eye LED's
dave330i is offline   Reply With Quote
Old 10-04-2008, 05:19 PM   #16
neil1138
^^^ more info on the hyundai part? If it's the same part for less, I'm all over that.
Old 10-04-2008, 05:24 PM   #17
Chris C
My Ride: 2001 325Ci
I wish I had known about this. I went the aftermarket route for the MAF and it cost me a little under $100.00 shipped. I would have preferred OEM but when I was looking for the part it was about $300.00 or so. Fortunately, I haven't had any problems with the aftermarket MAF. I posted about it a while back in the following thread:
http://forum.e46fanatics.com/showthr...&highlight=maf
Chris C is offline   Reply With Quote
