will this work - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-04-2008, 11:36 PM   #1
S54DR
My Ride: 332i/zhp/06 ZCP
will this work
will a crank out of a 95 s50 m3 work in a m52tu if so any mods to be done or will it bolt right up
S54DR is offline   Reply With Quote
Old 10-05-2008, 09:03 AM   #2
_Calle_
My Ride: 330Ci ESS TS2
Send a message via ICQ to _Calle_
This works very well!
in Germany there are some this have made.
Variation 1 on 3.0 l (base: M50 grey iron block):
Crankshaft of the M3 3.0 US implementation. This has towards of the "normal" M3 crankshaft the advantage that the connecting rod plugs measure 45 mm (otherwise, 50 mm) and one is not bound therefore to the substantially more expensive M3 connecting rods. Moreover, KW of US-M3 is substantially more favorable.
Connecting rod 135 mm or US-M3 3.0/3.2
piston 86 mm of US-M3 3.0
The block must be drilled out on 86 mm.
ZK poetry is natural to use from US-M3 3.0/3.2 then (11 12 1 405 106) compressions corresponds to the M3 3.0 USA
copied from seite http://wp1016621.wp027.webpack.hoste...140/f01140.htm
_Calle_ is offline   Reply With Quote
Old 10-05-2008, 08:28 PM   #3
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
You would be going from a forged crank to a cast crank. Get the S52B32 crank, and you'll be at 3.0L
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
