Thread Tools Search this Thread Rating: Thread Rating: 55 votes, 4.98 average. Display Modes
Old 08-08-2010, 11:21 PM   #21
miyata
My Ride: 2005 330 XI
Originally Posted by FFWD View Post
Has anyone tried cleaning the evaporator by removing the blower fan assembly? According to some, it can be done in 20 minutes, and exposes the entire evaporator. Here is a DIY on the fan removal (start at post 50 for the updated steps with detailed pics):
http://forum.e46fanatics.com/showthread.php?t=418987
Sound you have done this, am I right? How to dry the fluid if I flushed evaporator? Turn on the AC right away?
miyata is offline   Reply With Quote
Old 08-10-2010, 02:25 PM   #22
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
Thanks for the writeup
phamine is offline   Reply With Quote
Old 07-02-2011, 06:55 PM   #23
rkreimer10
My Ride: 2001 325i
subscribed, need to do this!
rkreimer10 is offline   Reply With Quote
Old 07-09-2011, 06:38 PM   #24
amish_car_racer
My Ride: 1999 323i
Sick of smelling the dirty gymsock when I turn on the AC, I decided to access the evaporator coil the way FFWD references. I left the blower in and shot through the fan grills as well as under the blower. I was able to shoot the whole can onto 90% of the evaporator. While I was in there, I decided to clean some of the grills of the blower...What a difference! The blower was sending out cold air about twice the velocity than it was prior to doing this and it didn't stink.
Thanks!
amish_car_racer is offline   Reply With Quote
Old 07-09-2011, 07:10 PM   #25
eimajamie
My Ride: '99 BMW 323i
Awesome write up. And thanks! :-)
Sent using BimmerApp
eimajamie is offline   Reply With Quote
Old 07-24-2011, 04:55 PM   #26
2002BMW325CI
My Ride: Car
That Smell has nothing to do with Evaporator. It's a well known problem for all the BMWs. The smell starts to come after 3 or 4 years from the insulation rubber used in Sound system to dampen the sound and also the insulation used underneath the seats.
Read these :
http://chimicles.com/case/bmw-odor
http://digg.com/news/offbeat/abnorma...on_odor_tossed
2002BMW325CI is offline   Reply With Quote
Old 09-22-2011, 02:27 PM   #27
Jmarlowe330i
My Ride: 2003 330i
well i got me a weekend project on my hands cause my sheet stinks lol
Jmarlowe330i is offline   Reply With Quote
Old 02-18-2014, 10:02 PM   #28
Zpzp96
My Ride: BMW E46 330i
This is very helpful to many people since our cars are old.
Zpzp96 is offline   Reply With Quote
Old 08-04-2014, 08:54 PM   #29
TitanXT
My Ride: BMW 330Ci
I have just done this today by removing the blower fan cover in the engine bay to reveal the evaporator coil. I also did not remove the fan.
I sprayed Wurths AC disinfectant spray - whole can. Took me nearly 2 hours to do the whole job. Seems to have done the job.
TitanXT is offline   Reply With Quote
Old 09-13-2016, 10:23 PM   #30
mp333
My Ride: 2003 325XI
Made sure the drain was unclogged by running the AC and confirmed condensation was coming out from the drain tube.
I did the Frigi Clean 709 and attached the nipple it comes with to the blower cover. Attached the tube it comes with to the nipple and empty the can while the AC is running on max and now don't have to worry about the air inlet being open.
You can leave the nipple in their ans cap it off. There is enough room on the Blower cover to connect the nipple. Mine just cleared the cover that goes in front of blower cover that supports the cabin filter. You could move it up by 1/2" or so... Next year just plug in and clean.
And then sprayed the Frigi Fresh to finish off.
Worked like a charm.
ID:	640930   Click image for larger version
E46 & E90 Rocks
mp333 is offline   Reply With Quote
Old 02-08-2017, 11:10 PM   #31
zhpposter
My Ride: ZHP
My attempt to clean the evaporator coil today (pics)
Thanks! This helped me do a necessary cleaning as my AC was beginning to smell musty and a reason to replace FSU.
Foaming cleaner can be bought at Kia/Toyota/Subaru dealers for 25 and Lysol is recommend by BMW via TIS service bulletin.
Kit also comes with an AC refresher than can be sprayed thru cabin air filter ducts.
I managed not to remove footwell AC duct.
I ended up using all the can of foam cleaner and half bottle of Lysol.
Overall, the car smells much better and no longer has bacterial smell.
zhpposter is offline   Reply With Quote
