Squealing Front Brake - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 10-06-2008, 09:36 AM   #1
Leon_s
My Ride: 318i
Recently I notice that my left front left brake is squealing when traveling slowly after a short stop. Can anyone shed some lights on this?
thanks
Leon_s is offline   Reply With Quote
Old 10-06-2008, 10:34 AM   #2
Chris-TK
My Ride: Mk VI GTI
If it's during braking it could be a worn brake pad. If it's after you have released the pedal then it might be a sticking caliper.
K.
Chris-TK is offline   Reply With Quote
Old 10-07-2008, 08:50 AM   #3
Leon_s
My Ride: 318i
when the pedal is released. How do you fix a sticking caliper?
Old 10-07-2008, 10:45 AM   #4
Mike In Mass
My Ride: '02 330 Convertible
It's either from corrosion or contamination from seal failure if indeed the caliper is sticking. You have a choice of rebuilding or replacing. If it's not bad, a rebuild will work fine. You don't say how many miles on it. You need to do some more investigating to determine your options. Best of luck.
Mike In Mass
Mike In Mass is offline   Reply With Quote
Old 10-10-2008, 04:34 AM   #5
Leon_s
My Ride: 318i
my car has 40k kms on the clock. I haven't done anything to the brakes yet since the day I bought it (abt 8000kms ago).I'll have it checked asap
Old 10-10-2008, 04:33 PM   #6
Kanaljen
My Ride: 2002 330i, Honda F4
Consider that you only have 40k km, about 25k miles, I would recommend to try some tlc first.
- If the pads are getting thin, replace
- Use some anti squeal paste inside the new pads
- You could change the rotors too but it's about $80 a side I would guess. Some turn the OEM ones... I don't, I like to get fresh ones when I change pads.
- Clean and re-grease the two caliper pins. Consider "upgrading" to solid brass guides and new pins.
- Inpect brake lines and brake pad sensors, replace as needed.
- Inspect and adjust parking brake assembly
(Don't forget to dissengage the p-brake when taking off the rear rotors...
- Flush the brake system (since you should consder bleeding the brakes anyway, just do so a lot and thus replace the brake fluid) You can have some one pump the brake pedal or just do what I do; pressurize the brake reservoir with one of those pump canisters..
Just my suggestions.. maybe just change the pads if they are worn as a first step..
02 330i, b-sapphire, L&S package, Tan/black leather, 18" M72, Tint, Sway bars, F & R strut braces, LTW flywheel, M5 clutch, 3.15 diff, Modded exhaust, SSK, U-drive pullies, Clear front corners, smoked tail and sides, stealth bulbs, B/W roundels, blacked-out emblem, trunk spoiler, Bi-xenon, angle eyes, HID fog lights, drilled Brembo, LTW battery, VDO gauges, Premium HK, extra amps & subs, ESS S/C, PS2 235,265, pss10, adj rear ctrl arms, IC coming
Kanaljen is offline   Reply With Quote
