03 325xi transmission fluid question - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-06-2008, 11:06 AM   #1
tums
My Ride: 2003 325xi
I have used the search option and cannot come up with a definitive answer.
I have a 03 325xi with 68k miles. It has the steptronic automatic transmission. I am the second owner having bought the car at 30k. My car is going in to my independent next Monday for some preventative maintenance: belts, coolant, diff fluid, fuel filter, valve cover gasket. I am going to replace the spark plugs and power steering fluid this weekend myself. I am wanting to get to 140k without any major issues.
Do I need to or should I change the transmission fluid? My independent tech says the lifetime fluid is BS and I agree. From the service records the ATF fluid has never been changed. Is 68k too late to change?
I read all these horror stories about the ATF failing after a transmission fluid drain at high mileage. Is this isolated to 99-02 ATF E46 or does apply accross the series. So should I change the fluid or leave it and pray?
tums is offline   Reply With Quote
Old 10-06-2008, 11:22 AM   #2
Colemanator02
My Ride: 2002 E46
The answer is, there is no definitive answer. You have to evaluate your scenerios.
Colemanator02 is offline   Reply With Quote
Old 10-06-2008, 11:56 AM   #3
NorCal Einstein
My Ride: E92 335i
Send a message via AIM to NorCal Einstein Send a message via Yahoo to NorCal Einstein
I would personally rather change the ATF and then pray and hope things don't die, rather then keep the original fluid in there and pray.
Current:
2009 E92 335i Alpine White/Coral Red
Past:
2007 E92 335i Sparkling Graphite/Black
2000 E46 323i Steel Blue/Grey
NorCal Einstein is offline   Reply With Quote
Old 10-20-2008, 06:11 PM   #4
reynaldo
My Ride: 2001 325i Sedan
Send a message via Yahoo to reynaldo
These are all DIY. Although it will take much of your time if DIY Changed Prev Mainteinance: Trans fluid and filter w/ESSO, Replaced 2 upper/lower hoses, WP, Thermostat, 2 belts, Temp Sensor, Leveling switch, Coolant Thermostat, 2 pulley, expansion tank of course new coolant. Whew. Currently I have 63,345 mileaage on 2001 325I Sedan Steptronic
reynaldo is offline   Reply With Quote
Old 10-20-2008, 06:20 PM   #5
MindTrack
My Ride: bmw
I changed mine for the first time at 130k and had no problems.
MindTrack is offline   Reply With Quote
Old 10-20-2008, 06:20 PM   #6
GRIDLOCK
My Ride: E36 / E46
I think you meant your transmission failing after a fluid change.
Catch 22 in regards to changing your fluid or not. I'm with a previous poster though, I'd change the fluid rather than not changing it.
Have an EVAP code? Replacing gas cap did not fix? Give me a holler, I can do a smoke test for ya.
GRIDLOCK is offline   Reply With Quote
Old 10-20-2008, 06:27 PM   #7
Bimmer Dude Xi
My Ride: 03 325XI 07 ZX-6R
Send a message via AIM to Bimmer Dude Xi
At what point of mileage is transmission fluid is supposed to be changed? Also what type of fluid is supposed to be used?
|Dinan High Flow Air Box|Eibach Pro Kit|Koni Sport|UUC Strut Barbarian|UUC TSE3|UUC Underdrive Pulleys|18" VMR V710|
|BMC Race Air Filter|CRG Spectrum Levers| Galfer Steel Braided Brake Lines|Volar Motorsport Spiked Frame & Bar-end Sliders|
Bimmer Dude Xi is offline   Reply With Quote
Old 10-20-2008, 06:33 PM   #8
CessnaPilot
My Ride: '04 325xi, '04 Titan
How did the outgoing fluid look?
CessnaPilot is offline   Reply With Quote
Old 10-20-2008, 06:57 PM   #9
xi_ter
My Ride: 2003 325xi
The ATF is coming to the end of it's life now. Looking a photos of some lifetime ATF, it starts to get grey sludge in it (formerly were detergents). If you change now, the grey sludge drains out and any remaining gets dissolved by the detergents in the new ATF. I used the Red Line D4 ATF.
