Powerflex pros and cons? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 10-08-2008, 12:19 AM   #1
mccal
My Ride: 325iSP
I am deciding on replacing my OEM bushing with powerflex but I hear some positive and negative comments. Can anybody who has it on their car give me your comments?
mccal is offline   Reply With Quote
Old 10-08-2008, 12:43 AM   #2
paraklas
My Ride: ESS TS2 320ci
If you are replacing the sway bar bushings as well, make sure to get uprated brackets too
Old 10-08-2008, 12:01 PM   #3
wlmmn
My Ride: '13 Infiniti G37x
Are you talking about the front control arm bushings? I replaced my OEM bushings at 65,000 with Powerflex bushings. Much improved steering response, and that with a new alignment, I smiled all the way home from the shop. I didn't notice any negative effects at all; I would recommend them.
wlmmn is offline   Reply With Quote
Old 10-08-2008, 12:09 PM   #4
mccal
My Ride: 325iSP
Tech notice cracked front control arm bushings when service was being peformed. I was quoted about $700.00 to replace both bushing. I haven't done it yet but was considering Powerflex bushings. Do you need to alignment after you replace the bushing?
Old 10-08-2008, 12:27 PM   #5
n2Bimmer
My Ride: Loves Corners
if your doing the front bushings then there may not be a down side, but if you do the rear arm bushings i hear tehy make noise
Old 10-08-2008, 12:43 PM   #6
wlmmn
Usually alignment is recommended. I'd do it. I remember reading somewhere on this forum that it is possible to replace the bushings without the alignment being out of whack by simply replacing them, but usually by virtue of driving around on worn bushings, the alignment is a little off. The bushings improve the steering response so much there's no need to have slightly off alignment spoil the fun of having the new bushings.
Old 10-08-2008, 12:50 PM   #7
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
I like them -
http://forum.e46fanatics.com/showthread.php?t=596462
Tim
tim330i is offline   Reply With Quote
Old 10-08-2008, 12:54 PM   #8
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
Ripoff. My tech did my front CABs for half an hour labor. And it literally took half an hour. $40 plus the cost of bushings (what, $70 from Tischer?).
-Brendan
Old 10-08-2008, 01:09 PM   #9
shady3one3
Banned
shady3one3's Avatar
My Ride: gets replaced soon.
Send a message via AIM to shady3one3
They squeak, they crack, and they are no better than fresh OEM ones. I use OEM e46 m3 bushings w/an aluminum sleeve
shady3one3 is offline   Reply With Quote
Old 10-08-2008, 01:21 PM   #10
Red 90
My Ride: 325i
That seems pretty high price too. It took me half an hour to change at my bushings mechanics shop while I was doing my suspension. Granted I did buy the bushings with the carriers so I didn't need to press anything out. I got the Meyle Heavy Duty bushings. I'm quite happy with them.
Red 90 is offline   Reply With Quote
