Sponsored by BimmerWorld
Old 10-08-2008, 03:41 PM   #1
Nesty
My Ride: 328i
What color are the stripes on ZHP springs?
I just bought a set of used ZHP springs for my 99 328i. I was wondering if any of you guys knew what color the stripes on the springs should be?
Thanks!
Nesty is offline   Reply With Quote
Old 10-08-2008, 04:16 PM   #2
TxZHP04
My Ride: ESS TS2+ ZHP
IIRC, red-white for the front and green-green-green for the rear. Member jpr has a thread around here somewhere with all the spring information in it.
Old 10-08-2008, 04:20 PM   #3
SeanC
My Ride: 330i
I have green-green-green (rear) on my sedan. Don't remember the fronts.
Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
HellrotDove Grey e36///M3 - RIP
Alpine WhiteTanSand High Gloss e46 330i SlickTop/5MT - Sold
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
SeanC is offline   Reply With Quote
Old 10-08-2008, 04:56 PM   #4
TxZHP04
I can verify once I get home, mine are just sitting on the floor in the garage.
Old 10-08-2008, 06:19 PM   #5
jpr
My Ride: '99 323i
There is no such thing as unique ZHP springs, there are only 330 springs. Exactly which springs were used depends upon the options that add weight to the car.
If you've already got the sport suspension on your 328, you are better off sticking with the springs you've got. If you do not have the sport suspension, bear in mind your drop will be somewhat less than 15mm on average with more in the front than the rear due to the differences in overall wieght and wieght distribution between the 330's and 328's
jpr is offline   Reply With Quote
