Sponsored by BimmerWorld
Old 10-08-2008, 09:11 PM   #1
DutchMaster
My Ride: 1999 323i
Spring Hats
Ok can someone tell me where i can buy the hats for a 2002 M3. I need them to install the suspension on my 323i thanks for the help.
DutchMaster is offline   Reply With Quote
Old 10-09-2008, 11:50 AM   #2
Chris-TK
My Ride: Mk VI GTI
You could order them from Tischer at getbmwparts.com
K.
Chris-TK is offline   Reply With Quote
Old 10-09-2008, 12:13 PM   #3
TxZHP04
My Ride: ESS TS2+ ZHP
You're going to put a stock M3 suspension on a 323? Let us know how that works out for you... I'm guessing you're not going to be too happy with the results. But then again, other than the potential increase in ride height, it's probably not much worse than some of the cheap coilovers other members put on their cars.
Old 10-09-2008, 06:23 PM   #4
DutchMaster
My Ride: 1999 323i
Wait why do you say that i am not going to be too happy with the results the car stiffens up a lot. When i only had the back set on i could feel the difference. My other question is will the M3 front strut mounts fit on my car if they will that makes life a lot easier but if they dont what will i need to buy to get it to work Thanks for the help[
