Sponsored by BimmerWorld
Old 10-08-2008, 07:52 PM   #1
Motorx1000
My Ride: 2002 Bmw 325ci
install need help asap!! springs help
im in the middle of commpressing my stock springs.. i compress them fully with no pressure on the hat ...and then when i go to take the top hat.. that bolt thats 21 mm ya i never comes off.. the whole hat spins and i the bolt doesent loosein. what am i doing wrong.?
please help ive been working for hours on this crap and im ready to just put everything back together.btw i looked at the tech thread.
Motorx1000 is offline   Reply With Quote
Old 10-08-2008, 10:09 PM   #2
Tom Busby
My Ride: 2001 325i, 1995 318i
You can try a 13/16" spark plug socket from any auto store, so you can wench on the flats of the tool and fit a torx wrench down the middle of the tool. Or buy the correct mm tool.
Tom Busby is offline   Reply With Quote
Old 10-08-2008, 11:10 PM   #3
Motorx1000
its not the size of the socket. its that it just wont loosen. the strut is not oem i think that could be it. it has a weird looking hat nut that seems to have an allen key nut over it making it weird. when i try to turn the bolt it just turns the whole strut and the stays in place spring.
Old 10-08-2008, 11:17 PM   #4
TxZHP04
My Ride: ESS TS2+ ZHP
Re-read Tom's post more carefully. He's suggesting you utilize something like this:
http://www.grainger.com/Grainger/items/1AK01
...using a wrench on the outside so that you can run a hex bit through from the top to stabilize the shaft while you turn the nut via the outer socket.
Old 10-10-2008, 02:59 PM   #5
Motorx1000
ohh ok.. i think that could be it. my struts arent oem so thats why i think i ran into this problem.
Old 10-14-2008, 03:12 PM   #6
Motorx1000
so i need A 13/16 sparkplug
