Old 10-13-2008, 12:43 PM   #1
vinnybones
My Ride: E46 330i & E46 M3
Need help fast!
i was putting in my pia hyper white lights and the side with the airbox its hard to get to so i undid it and i had to pull the top up a little and i ended up tearing the tubing that runs from the engine to the airbox (mass air flow?) now my service engine lights on and cars acting funny..is there simple repair like just electrical taping it back until i can get a new 1? and should i just buy a K&N intake or replace the oem? thanks!
vinnybones is offline   Reply With Quote
Old 10-13-2008, 01:48 PM   #2
vinnybones
bump!
Old 10-13-2008, 03:08 PM   #3
MATT0404
My Ride: F800GS
A solution to your problem depends on the extent of the damage. From your description it seems like you are talking about the MAF sensor wires. A bundle of wires that are wrapped in a sheath that connect at the back of the airbox to a square/rectangle sensor and run back towards the engine block? Did you pull the wires out of the sensor or did one, or more, of them break in-line? You're going to have to establish the exact problem before we can help you fix it. If it is non-repairable then changing out the intake system isn't going to fix it since every intake will require the use of that same sensor.
MATT0404 is offline   Reply With Quote
Old 10-13-2008, 03:46 PM   #4
Bimmer Dude Xi
My Ride: 03 325XI 07 ZX-6R
Send a message via AIM to Bimmer Dude Xi
I hate that poor design of having the airbox close to the headlight and also some of the clips of the airbox are tough to get to.
|Dinan High Flow Air Box|Eibach Pro Kit|Koni Sport|UUC Strut Barbarian|UUC TSE3|UUC Underdrive Pulleys|18" VMR V710|
|BMC Race Air Filter|CRG Spectrum Levers| Galfer Steel Braided Brake Lines|Volar Motorsport Spiked Frame & Bar-end Sliders|
Bimmer Dude Xi is offline   Reply With Quote
Old 10-13-2008, 05:11 PM   #5
vinnybones
the rubber tube that connects to the maf has about a 2" tear in it..all the wires are ok its just the rubber piping has a hole
Old 10-13-2008, 05:30 PM   #6
Bimmer Dude Xi
I would try sewing the rubber tube with a heavy weight fishing line tightly wound. After sewing it then paste on some silicone or any type of that to insure a good vacuum seal. This is for temporary.
Then buy a new rubber intake tube.
Old 10-13-2008, 07:50 PM   #7
vinnybones
where can i get the bmw rubber tube from and how much? and what about just buying a Air intake?
Old 10-13-2008, 07:51 PM   #8
frobie15
My Ride: has a door star
Send a message via AIM to frobie15
The tube is only $20 or so from the dealer. It's a bit of a pain to replace, though. Not impossible, just frustrating and time consuming.
Go ahead, ask me a question... Check out the CopTalk thread in the California forum
Thank you Sam
frobie15 is offline   Reply With Quote
Old 10-13-2008, 07:55 PM   #9
vinnybones
i tried to look for a DIY and couldnt find anything..im not sure what to type in..replacing rubber tube?!..i need to get this done asap..got a date on wedesday and cant be stalling out
Old 10-13-2008, 08:05 PM   #10
frobie15
I don't think there's a DIY. Seriously, it's not a complicated process. Just long and frustrating.
Thank you Sam
Old 10-13-2008, 08:13 PM   #11
vinnybones
lol well i figured since theres even a DIY for a tuna melt there would be one for this lol...do you know if its a part usually instock?
Old 10-13-2008, 08:27 PM   #12
frobie15
It was in stock at my local dealer the day I needed it. Just call and check. I don't know if all dealers stock the same parts.
Thank you Sam
Old 10-13-2008, 08:39 PM   #13
vinnybones
k thanks man I appreciate it
Old 10-13-2008, 09:14 PM   #14
MATT0404
My Ride: F800GS
Good one.
Old 10-13-2008, 11:42 PM   #15
Bimmer Dude Xi
If they have it, then you're a lucky one. Good luck
Old 10-14-2008, 03:41 PM   #16
vinnybones
so today i went in for the fix.I couldnt NOT get the rubber tube off lol so i did all the work underthe hood right there..i tried sewing it up but it was to strong and broke two needles..i got gorilla glue and put 2 coatings on the inside of the tube and 1 coating on the outside and wrapped tightly with gorilla tape...Car no longer stalls out due to choking on the air but SES light is still on...anybody know why?
Old 10-14-2008, 03:57 PM   #17
frobie15
Probably still leaking air, just not enough to make it die. You really do need to swap that thing out!
Thank you Sam
Old 10-14-2008, 04:00 PM   #18
vinnybones
yes I know..It gives me some time to figure out whether or not to buy Oem or just get aftermarket intake.
Old 10-14-2008, 05:14 PM   #19
frobie15
An aftermarket intake isn't going to fix the inlet hose. At least, none that I know of!
Thank you Sam
Old 10-14-2008, 06:59 PM   #20
vinnybones
ooo...yea the thing i couldnt get off is where the two tubes connect to the rubber tube think its the fss/ and something else..i couldnt remove them bitches..how the fuck are you suppose to get them off..i tried prying them..twist and pull.vice grib n pull nothing:{
