Noise when braking, and it's not the pads - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Old 10-14-2008, 09:23 AM   #1
nassersyed
My Ride: 2002 BMW M3
Hey guys,
I had a quick question- Whenever I'm braking and I happen to drive over a bump in the road or anything, I hear a "RRRRRRR" noise. It's not a squeak or anything. It happens only when I'm coming to a stop and if there's some kind of obstruction in the road, when I drive over it while braking my car makes a kind of sounds that can only be described as "RRRRRRRRR" and the braking pedal seems to go in a bit deeper.
Is this normal? It doesn't seem like it would be. Has anyone else experienced this? I have a 2002 M3, around 45K miles. I don't think it's the brake pad, and am kind of stumped.
Thanks in advance.
nassersyed is offline   Reply With Quote
Old 10-14-2008, 07:11 PM   #2
realcompm3
My Ride: Your wife
mine had done that. just check the brake fluid
realcompm3 is offline   Reply With Quote
Old 10-16-2008, 11:19 AM   #3
nassersyed
Brake fluid is full. Doesn't seem that that's it.
Old 10-16-2008, 03:20 PM   #4
driver dude
My Ride: E46 M3
Originally Posted by nassersyed View Post
Hey guys,
Thanks in advance.
It's not impossible for it to be the pads, so unless you have visually inspected the pads in the calipers, don't rule them out.
driver dude is offline   Reply With Quote
Old 10-16-2008, 04:43 PM   #5
dcf
My Ride: 02 e46 M3 SMG - LSB
Sure it is not just the antilock kicking in on the one wheel that hits the bump, etc.? That would explain the noise and the pedal drop. Different from when you slam on the hooks and 2 or 4 wheels go into antilock, which will cause a bigger pedal drop and more noise.
dcf is offline   Reply With Quote
brake, brakes, noise
