///M3 Forum
Old 10-14-2008, 10:08 AM   #1
5nkr259
My Ride: e46
HELP!!! SMG owners code P1717
anybody know what is this about?? launch tool report (056 on period,hydraulic unit) is this the smg relay fault?
5nkr259 is offline   Reply With Quote
Old 10-14-2008, 07:04 PM   #2
realcompm3
My Ride: Your wife
go to the dealer
realcompm3 is offline   Reply With Quote
Old 10-16-2008, 01:16 AM   #3
5nkr259
My Ride: e46
figured it out, for those who have this problem it stated (hydraulic pump is on period due to out of range operation short circuit!!! fixed with new smg relay and have your system clear up the error code...http://www.prior-chelt.co.uk/Files/bmw_pdf/SMG.pdf
dealer = stealer
Old 10-20-2008, 03:48 PM   #4
jateshk
My Ride: M3 Vet 100% options
I had the same exact code a few months ago. I will buy a new relay and get it installed. Hopefully this will do the trick!
jateshk is offline   Reply With Quote
Old 10-20-2008, 06:47 PM   #5
5nkr259
My Ride: e46
let me know if it helped!!!
Old 08-28-2009, 01:58 PM   #6
GQxPAT
Account closed.
I have a 2003 E46 M3. Just recently have the same problem. SMG Transmission light comes on and off then on again. Same code P1717. Brought it to the dealer. They ask me to replace 3 parts. SMG Reply ($15), Hyraulic Unit ($2,400), Program module ($1,000+), Labor ($1,020) = Total about $ 4,500 worth! I took my car back without doing any of the work. My feeling is that they don't know exactly what's wrong with it. I'm going to buy a SMG reply and test it out. Hope that helps!
GQxPAT is offline   Reply With Quote
Old 12-03-2011, 08:47 PM   #7
bkriaras1
My Ride: 2002.5 m3
did this help anyone, i am now getting these codes
bkriaras1 is offline   Reply With Quote
Old 12-03-2011, 11:34 PM   #8
Beamn46
My Ride: 02 M3 SMG CB/CINN
Send a message via AIM to Beamn46 Send a message via MSN to Beamn46
Replace the Relay.. is it just trowing the code or is your SMG down?
Beamn46 is offline   Reply With Quote
Old 12-04-2011, 01:30 AM   #9
bkriaras1
My Ride: 2002.5 m3
smg is working, just once in a while shifts from 2nd to 4th.
Old 12-04-2011, 01:42 AM   #10
bkriaras1
My Ride: 2002.5 m3
the gearbox will com on. and go away, then it will work properly
