Suspension & Braking
Have some questions about suspension or brake setups for your E46 BMW? Get all your answers here! |
#1 | |
After snapping the ARB brackets twice I decided to go a step ahead and get a complete ARB set (Front + Rear). Also, the addition of the S/C made me drive more spirited than usual hense the requirement for better road stability, and reduced body roll. After a lot of research, I ended getting the Hotchkis Sport Sway Bar Kit, with rear endlinks and adjustable stiffness. Initial impression is WOW. Very well packed from factory, power coated bars, grease, manual, parts list to make sure you don't miss anything, adapter plates etc.
![]() From the manufacturer: Quote:
![]() And here is what the UPS delivered: :wink: Very good packing!! Nothing moved! mmmm Thick bars! Manual and parts list Front bar, 3-way adjustable Don't like stickers but where this is going, nobody will see it. Rear Bar - 2 Way adjustable I was planning to do the install over the weekend but I managed to squeeze 3 hours of "lunch break" to do the install today ![]()
#2 |
very nice.. post a review after u install it!
#3 |
very nice, im still deciding between H&R and these, can anyone think of the differences, Such a weird name, where are they made.
#4 |
Congrats on the buy. You will LOVE them. I installed Hotchkis about 6 months ago and couldn't be happier. Handling is much tighter and feel much less roll on high speed turns. If you haven't already done so I would advise changing the end links, mine broke because the sway bars were too strong, plus if you get the adjustable end links you can not only adjust rear but fronts. Good luck with install!
#5 |
Hotchkis Sport ARB Install
Front Stock ARB Endlink connection The dreaded brackets that break all the time with the -now gone- powerflex bushes Install was very easy for the front one. Just remove the brackets, disconnect the endlinks and replace with new ARB. I set it to the softest mode as the manual suggests, but I will change it later on when I have time to test the handling characteristics. The PS hose was too close so we pushed it a bit out of the way. New bracket in place with greased bush Endlink connected at softest setting Now the rears were a bit more challenging to install. Had to drop the exhaust from the rear mounts to allow some extra space. Just a ratchet with an extension did the job. YESSSS No subframe damage!!!! Left is OEM Vs new bolts Rear ARB brackets removed Rear ARB removed with the endlinks & brackets still attached to it. A 17mm open wrench was needed to hold the bolt's head on the upper side of the control arm. Removing rear exhaust mounts to drop the exhaust a bit. Hotchkis doesn't mention this but my mechanic doesn't like following printed instructions blindly. Testing the new endlinks with the OEM brackets Securing them in place. We had to adjust the endlinks to lengthen a bit because the bar was touching the rear axles. Installing the brackets with the PU bushes. The OEM brackets are held in place by a single bolt, the Hotchkis has 2 bolts and a massive aluminum reinforcement plate to hold the bar in place. Adjusting endlinks to clear axle, screwing the exhaust back in place and DONE. Total time around 2 hours (10 minutes for fronts and 110 minutes for rear) Old stuff in trunk to go in storage Now, from the second the car touched the floor, the difference was noticeable. I will reserve my opinions once I manage to test the new setup in varying roads/conditions.
#6 |
sweet, so how much did it cost you, where are these made
#7 |
wow bro. nice string of PICS. another great addtion from a fellow fanatic. anyone on the planet thinking about this set up for their BMW will be well served by looking at this post. nice work.
02' Black Sapphire Metallic 330i
Sport, Cold Weather and Premium Packages * Dinan TCAI * Dinan Stage II engine software * Dinan performance tranny software * UUC TSE3 * ///M3 Steering wheel * ///M3 lip spoiler * UUC Slotted Front Rotors * Powerflex FCAB's * KONI FSD's * UUC StrutBarbarian * 35% tint * OEM (ULO) clears * 5000k bulbs * NGK Iridiums * Stewart WP * Delmarco's Bluetooth retrofit * LED Angel Eyes * 3K HID Fogs * USA Spec |
#8 |
Congrats! Helpful install write up as well.
- 2002 Steel Blue 325Ci -
#9 | |
The seller also has a website which sells www.lightningforceperformance.com I don't see any Made in.. but on the box it has date 10/08/2008 from an address in Santa Fe Springs, CA. I assume they are made in USA? I guess a call to hotchkis will solve this question. Thanks for the comments
#10 |
I bought mine from the same seller on eBay. And I believe the stickers were only for reference when installing them. Nice write up! I love mine.
#11 |
if this is you after the softest setting:
![]() this will be you at the intermediate setting: ![]() and at the tightest setting:
![]() Sapphire Black MetallicNatural BrownSilver Cube e46 330i ZHP/ZCW/6MT - Sold HellrotDove Grey e36 ///M3 - RIP Alpine WhiteTanSand High Gloss e46 330i SunRoofLess/5MT For Sale: $300 winter wheel/tire set (sport edition F7s and Dunlop graspics) For Rent: RTAB Removal/Installation and Preload Tools |
#12 | |
Hotchkis made a reputation making suspension parts for muscle cars. Only within recent time did the get into the sport compact & euro scenes. And for anyone that watched Sports Car Revolution when it was on TV, they were big fans of Hotchkis suspension parts. For sways & springs, it's hard to bet against Hotchkis, imho.
328i ZSP/ ZPP/ ZCW - Sold
![]() _________________________________ '99 DINAN 328i - Sold '93 Honda Civic Si - Sold |
#13 |
nice! i had mines for about 2 weeks now and i love it!
![]() JL Audio CleanSweep, JL Audio Mono 1000w Amp, JL Audio W6 v2 12in Sub, MB Quarts 6 1/2 components front, Polk Audio 6 1/2 Coaxial Rears, Lanzar 4ch 1200w Amp, K&N Drop in Air Filter, Black out grill/reflectors, 35% Tint fronts, F2 Coilovers, Hotchkis Swaybars, ECS Tuning 5mm Spacers, BF Goodies T/A KDW, UUC SS Brake lines, ATE Super Blue |
#14 |
I am pretty sure they are made in the US, and I believe the main difference is that they are tubular.
#15 | |
I have a set at home I bought 3months ago and have been dreading to install - guess I will have to pay someone to do it. If getting NEW endlinks, any recommendations out there? Will OEM (M3 or 330)ones work? Still on that, do I need an alignment afterwards? |
#16 |
Rear endlinks are included in the kit.
No you don't need an alignment You don't need to remove wheels, you don't even need jack stands. 2 good ramps and you are good to go.
#17 | |
#18 |
excuse me for my ignorance but what exactly does these sway bars do?
#19 |
Reduce body roll when cornering. Hence, "anti-roll bars" (ARB)
![]() Ground Control Street/School coilovers, 19" HRE 441R wheels, ACS exhaust 2DIN touchscreen carputer, Bimmian CF E-brake handle, Titanium CF Trim, Illuminated ZHP knob, BMW Performance SSK, 2-way Compustar Clear turn signals, LED license plate lights, LED tails, 3000k HID fogs, angel eyes, matte grills, CF Emblems etc |
#20 |
Front end link use OEM right?
