Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 21 votes, 5.00 average. Display Modes
Old 11-03-2008, 04:14 AM   #21
paraklas
My Ride: ESS TS2 320ci
Yes, OEM endlinks for the front although I'm going to upgrade since mine are pretty worn
Old 11-03-2008, 04:34 AM   #22
Dannyncc
My Ride: Aw m3
Send a message via ICQ to Dannyncc Send a message via AIM to Dannyncc Send a message via MSN to Dannyncc Send a message via Yahoo to Dannyncc
tempting. ... ...
Dannyncc is offline   Reply With Quote
Old 11-03-2008, 04:43 AM   #23
deafboy
My Ride: 2000 323Ci
I'm been going bar and forth for nearly a year now between these and H&R/Tuner.... the only reason I havent gotten these ones is cause the idea of a hollow sway bar scares me...lol.
-Cole aka bigtall*****
Originally Posted by Owtlaw333 View Post
You'll always be pretty in my eyes, Cole :luv:
Originally Posted by Chrissspyy View Post
i was like passed out while she's shoving the entire bar in my mouth. :rofl: :rofl:
deafboy is offline   Reply With Quote
Old 11-03-2008, 04:55 AM   #24
paraklas
Hollow Vs Solid
Hollow Vs Solid 2
Old 11-03-2008, 09:06 AM   #25
DanFromTucson
My Ride: 2004 330ci ZHP
You didn't happen to compare the weight of the bars vs. stock, did you?
DanFromTucson is offline   Reply With Quote
Old 11-03-2008, 10:00 AM   #26
paraklas
Total weight was 26 lbs for the Hotchkis. I'll weight the stock ones when I get back home. Bear in mind, mine are the thinest bars (M54B22 engine)
Old 11-03-2008, 04:03 PM   #27
Spaniardstud
My Ride: 2001 325ci
I have from a few different places that sway bar kits for the E46 make a squeaking sound is there any truth to this????
Spaniardstud is offline   Reply With Quote
Old 11-03-2008, 04:21 PM   #28
paraklas
After 3 weeks no weird squeaking sounds. I checked them last night and the grease is still around the bushes. The grooves inside the bush will also keep the grease inside for long I hope
Old 11-03-2008, 04:27 PM   #29
n2Bimmer
My Ride: Loves Corners
So whats the conclusion on the Hollow vs solid, dont feel like reading
Old 11-03-2008, 05:07 PM   #30
323iINt.o
My Ride: 328i
I remember when i got my UUC sways installed, I ALMOST CRASHED! lol
My dumba55 decides to go to the stiffest setting first time, i got way over-confident and almost lost it on a turn.
Learned my lesson 1 year ago, and progressed from soft to stiff. And now id never go back to OEM
NEED SMOKED CORNERS AND MARKERS, PM ME IF YOU GOT SOME!
323iINt.o is offline   Reply With Quote
Old 11-03-2008, 10:55 PM   #31
deafboy
My Ride: 2000 323Ci
Well after reading those I am even more scared of hollow ones.
What I got from it is that the only advantage to the hollow ones is the reduced weight.
A smaller solid bar is equilvelant to a larger hollow bar, the thicker the wall is on the hallow one the smaller it has to be to be equivelant solid bar.
Hallow ones, although lighter have reduced strength and increased stress
Tube torsion members can be used successfully as swaybars with some benefit in weight
reduction.
As an example, 2 individual, rate equivalent (approximately), common sized generic bars
1100mm long with 300mm blades, one solid 24mm the other tube of 25.4 x 3.96mm (1"
x 0.156***8221 gives a weight reduction of about 2.5kg with about 200g of that as unsprung
mass per wheel.
However the downside to these is the increase in stress levels for equal OD or rate, and
therefore reduced strength. Also the complications seen in manufacture swaybars from
tubular medium, and the importance of geometric control under bending make these more
difficult and expensive to make. The attachment points at the blades can also be a
problem with these swaybar designs.
The additional complications and downsides of hollow bars seem to outweigh their
advantage in overall weight and unsprung mass, which can be seen to only be marginal in
street car application. Even OE manufacturers rarely use this type of design in their
swaybars. However with the right conditions and setups, they can bring some gain in
racing situations, which can require weight reductions to the gram.
Old 11-03-2008, 11:44 PM   #32
TxZHP04
My Ride: ESS TS2+ ZHP
Stock bars from my ZHP weighed about 17 lbs according to my scales. No guarantees on the accuracy but it's probably within a pound +/-, maybe 2. Of course, comparing the weights of bars of dramatically different stiffness isn't a meaningful comparison though. Unfortunately I don't have the weight of my H&R bars.
Old 11-04-2008, 01:11 AM   #33
n2Bimmer
i think H&R being solid is better
Old 11-04-2008, 01:23 AM   #34
MJRMatt330
My Ride: 2002 330Ci
Send a message via AIM to MJRMatt330
i want either a set of H&R or Hotchkis soon!
Mods
Exterior- M-tech II front, M3 Lip, Predator Chromiums 6000K, 6000K xenon, matching fogs, 30% tint, Eagle Eye LED's, Staggered 19" CSL's w/ Falken 452's
Performance- CF Dinan CAI, 3.38 Diff, Ebay Headers
Interior/Sound- Tri-M3 wheel, Leather ///M shiftknob, DICE iPod integration, JL Audio 10" Whoofers, Custom Box, JL Audio 250/1 Amp
MJRMatt330 is offline   Reply With Quote
Old 11-04-2008, 01:30 AM   #35
paraklas
Does H&R give any specs for their bars like Hotchkis?
Bar Rates lbs/in (Not Wheel Rate)
Front:
470 lbs/in.
540 lbs/in.
630 lbs/in.
Rear:
475 lbs/in.
540 lbs/in.
Old 11-04-2008, 01:32 AM   #36
n2Bimmer
ya me too man, are H&R and hotchks the same thickness in diameter.
Old 11-04-2008, 02:05 AM   #37
deafboy
My Ride: 2000 323Ci
Front:
470 lbs/in.
540 lbs/in.
630 lbs/in.
Rear:
475 lbs/in.
540 lbs/in.
havent seen anything.
Old 11-04-2008, 02:06 AM   #38
deafboy
My Ride: 2000 323Ci
No...hotchkis are a bit thicker.
Old 11-04-2008, 10:12 AM   #39
SeanC
My Ride: 330i
That's what she said.
That's what she said, too.
Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
HellrotDove Grey e36///M3 - RIP
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
Imola RedBlackBlack Aluminum e46 330i ZHP/6MT
SeanC is offline   Reply With Quote
Old 11-04-2008, 10:48 AM   #40
DanFromTucson
I assume that's 26 lbs for the package weight with cardboard, styrofoam, etc. correct?
I also assume the post about ZHP bars weighing 17 lbs is just for the bars themselves with no endlinks, brackets, bushings, etc.
Still, if the ZHP bars are 17 lbs, I guess there's not too much weight to be saved anyway.
