Thread Tools Search this Thread Rating: Thread Rating: 24 votes, 5.00 average. Display Modes
Old 10-17-2008, 03:48 PM   #1
owen_mc
My Ride: 325ci sport cab
DIY: HID Capacitor Mod
Hi all...
Ref: E46 325Ci sport convertible 2002
In a recent post I discovered I had to make a modification to the wiring loom to get an after market Xenon head light kit working. This problem caused the lights to fail or flicker only when the engine was running. With the great help I made the modifcations and took some photos on the way:
This is what we are trying to achieve:
1. You will have a plug with a grey end which plugs into your orginal headlight, this has 2 wires coming off of it which are brown (earth) yellow (live). You need to expose the wire by cutting back some of the insulated plastic coating, like so:
2. You shall then have to solder 2 short pieces of wire from each of these exposed areas of wire:
3. These will need to be connected too the capacitor, I have used a screw type ficing here as i felt that if I need to replace the capacitor, this will allow me to do so stress free. Please note that minus to minus and plu to plus on the capacitor!
4. You should have something that looks like this:
Mines abit messy in the pictures, in order to show what I did. I have now taped all away and hidden. The lights now work perfectly.
The capacitors are on maplin website, Code VH57M is the one (PC Elect 4700uF 16v - 61p each):
http://www.maplin.co.uk/Module.aspx?ModuleNo=13472
BWW 325ci Sport Convertible (2002)
owen_mc is offline   Reply With Quote
Old 10-17-2008, 04:08 PM   #2
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
nice diy.
Do the hids stay on for a tiny bit longer after you turn them off?
SL Blak Soldier is offline   Reply With Quote
Old 10-17-2008, 04:26 PM   #3
owen_mc
Nope... but if you flash the head lights before you get out the stay on for like 30 seconds anyway!
Old 12-12-2008, 10:28 PM   #4
ThunderRobo
My Ride: E46 Sedan
Send a message via MSN to ThunderRobo
What was the specs of the capacitor you used?
ThunderRobo is offline   Reply With Quote
Old 12-17-2008, 02:58 PM   #5
sdbimmer
My Ride: 2004 325Ci
Don't forget that these capacitor has polarity. If you look at the picture, there is an arrow. If memory serves me, the arrow lead is suppose to point ot the negative (Brown) wire. If you do it the other way around, it will overheat and blow out the capacitor.
http://www.radioshack.com/product/in...ductId=2102508
sdbimmer is offline   Reply With Quote
Old 01-16-2009, 01:27 PM   #6
TKC
My Ride: 330cic & R6
Send a message via AIM to TKC
This will help with my cousin's install... thanks!
EUROPROJEKTZ - Director, NorCal Chapter
TKC is offline   Reply With Quote
Old 02-25-2009, 06:23 AM   #7
Wezza
My Ride: 2004 318i Sport
Mine has the same problem! Cheers for the info.
MODS: VMR Hyper Black CSL Reps, CF splitters, ACS rear roof spoiler, P46 projector headlights, Orion V2 angel eyes, 6k HID low beams.
Wezza is offline   Reply With Quote
Old 06-28-2009, 09:51 AM   #8
Gobanna
My Ride: E46-318i SE
Thank You !
I never had the flicker or any other on or off issues regarding 35W, I only had the bulb out error when I upgraded to 55W (once lights were on the bulb out error disappears).
I used the capacitors you recommended and followed the project install at :
http://www.argyrides.eu/bmw/mods/bi-.../xenon_lcm.htm
(wanted it to be as tidy as possible)
What you need:
1. 2 x 4700uF Capacitors at 16v (one for each headlight)
2. 2 x Small project boxes to fit capacitors in (A must for stock install, nice and tidy)
Everything is fine with no bulb out error ! Thanks !!!
Gobanna is offline   Reply With Quote
Old 10-22-2009, 12:59 PM   #9
manilaboy1vic
My Ride: 2002 330Ci
some are using 16v and others 35v, whats the deal?
manilaboy1vic is offline   Reply With Quote
Old 12-15-2009, 01:42 PM   #10
thadon1883
My Ride: M3
seriously....i need to do this mod this weekend, which capacitor should i get the 16V or the 35V??
thadon1883 is offline   Reply With Quote
Old 12-15-2009, 01:49 PM   #11
sdbimmer
My Ride: 2004 325Ci
your battery and alternator voltage doesn't even go up that high, so it shouldn't even matter. But the 35v 4700uF is fine...
Old 01-21-2010, 06:15 PM   #12
Skiracer41
My Ride: wastes my money
sweet
Skiracer41 is offline   Reply With Quote
Old 07-24-2012, 05:00 AM   #13
Toxx
My Ride: 2000 323i
Does anyone know where I can get any of these capacitors? RadioShack is sold out and I need my headlights to work..
Toxx is offline   Reply With Quote
Old 07-24-2012, 11:36 AM   #14
sdbimmer
My Ride: 2004 325Ci
cap
Did you try different location in your area?
Is there a Fry's Electronics in your area? they have some too.
Old 07-26-2012, 03:18 AM   #15
Wofy
My Ride: 318I E46
As for the capasitor voltage, 16v should work but i would put a 35v as the normal working voltage of the car is 13,8v but seems that it is not a perfect electronic circuit it may have peaks that go over 16v, a few peaks will not damage the cap but if you have a older BMW this might cause the cap to blow in a bit of time. 35V caps are just a little bit bigger but much better in this case i would say, plus if you find gold lined caps they are even better because they resist better to heat. I would recomend this one:
http://it.rs-online.com/web/p/elettrolitici/7328254/
It has a 105c 221f working temp
Wofy is offline   Reply With Quote
