Sponsored by BimmerWorld
Old 10-19-2008, 02:24 AM   #1
silentak1
Banned
My Ride: '03 330ci cabrio
Which RTAB would you buy?
I need to replace my RTAB's and am having some trouble finding the sturdiest one of all:
Lemfoerder PN 33326770786
(Half/Half casings)
Lemfoerder PN 33322228153
(Single casing)
OEM M3 PN 33326770817
Meyle PN 33322228153
I'm noticing that there are models with "split casing/housing" and others in "full casing/housings". See attachment... I'm guessing that the full housing will retain the rear-toe more in spec during heavy cornering and acceleration?
I don't want a flimsy floating feeling, what is the recommended RTAB?
ID:	288561   Click image for larger version
silentak1 is offline   Reply With Quote
Old 10-19-2008, 02:51 AM   #2
TX
My Ride: '01 330i ZSP ZPP
Send a message via ICQ to TX Send a message via AIM to TX Send a message via MSN to TX Send a message via Yahoo to TX
UUC urethane RTAB!
TX is offline   Reply With Quote
Old 10-19-2008, 08:36 AM   #3
Hrvat
My Ride: 02 Imola Red M3
Get a E46 M3 RTAB from www.autohausaz.com
PM ME FOR FREE SAMPLES
Originally Posted by roronoah View Post
so 2004 bmw's dont come with a diff?
Hrvat is offline   Reply With Quote
Old 10-19-2008, 09:26 AM   #4
TxZHP04
My Ride: ESS TS2+ ZHP
I would highly recommend either the OEM M3 or the Meyle HD, part # 3003332104/HD, which uses a similar construction. Note that this Meyle part number is different than the one you listed above - not sure but that may be the old BMW part number that you listed. The flanged design is the older design that BMW has moved away from, the split casing is the newer design. When installed, the 2 halves of the casing are squeezed together compressing, and stiffening, the rubber interior.
You won't have a flimsy floaty feeling with either of the above recommended new bushings but if you want additional toe control that will also help the bushings last longer, I would also recommend that you pair them with a set of Vorshlag limiters:
http://www.vorshlag.com/product_info...products_id=59
I'm running these limiters with OEM M3 bushings and it's a great setup.
Old 10-19-2008, 11:17 AM   #5
silentak1
Banned
I think I will go for the Meyle HD (3003332104) and as backup the OEM M3 (33326770817). The UUC's are just too stiff for my huse and I don't want to deal with the possibility of creaks.
For some reason, autohausaz.com only shows me the Lemfoerder M3 bushings and not the OEM ones. Does anyone have recommended places for the Meyle HD RTAB's?
Old 10-19-2008, 11:24 AM   #6
jpr
My Ride: '99 323i
I'd recommend the lemforder M3's over the Meyle.
jpr is offline   Reply With Quote
Old 10-19-2008, 11:27 AM   #7
kpeng
Banned User
My Ride: E46 330 and E30 325
Meyle HDs with the Turner Motorsport Limiter kit.
I have this setup and I love it.
kpeng is offline   Reply With Quote
Old 10-19-2008, 11:41 AM   #8
silentak1
Banned
For the Vorshlag limiters, are these just plastic washers that go at the ends of the RTAB's WITHOUT any drilling?
Thanks jpr. PelicanParts shows the Lemforder M3 bushing as the old PN 33322228153 and the old single piece housing. What do you think?
And the OEM M3 from PelicanParts (33326770817)
Old 10-19-2008, 11:49 AM   #9
Hrvat
www.autohausaz.com has M3 RTABs. That's where i got mine from
Old 10-19-2008, 12:14 PM   #10
TxZHP04
The Vorshlag limiters require no drilling, they just wedge into place. IIRC, they are also quite a bit cheaper than the Turner limiters and every bit as effective.
Don't get the old style one-piece flanged bushing. I ordered the new style M3 bushing directly from Tischer.
Old 10-19-2008, 05:35 PM   #11
jpr
My Ride: '99 323i
I'm with TxZHP04 on this, might as well get the new style (the -817) bushings. Attached is what the ETK shows for part number history on the M3 RTAB's
Old 10-19-2008, 10:08 PM   #12
silentak1
Banned
Thanks, just placed my order for the Vorshlag limiters.
Thanks jpr. I'll look for the newer model -817.
Old 10-20-2008, 12:14 AM   #13
n2Bimmer
My Ride: Loves Corners
OEM M3 RTAB with shims/ limiters.
Old 10-20-2008, 02:14 AM   #14
ryyster
needs a proper photoshoot..
ryyster's Avatar
My Ride: -----
Good choice
ryyster is offline   Reply With Quote
Old 10-20-2008, 07:59 PM   #15
SilvaBimma
My Ride: 330Xi
What about Powerflex RTAB? Don't the M3 RTABs breakdown overtime, like usual OEM e46 RTABs?
SilvaBimma is offline   Reply With Quote
Old 10-20-2008, 08:04 PM   #16
silentak1
Banned
Thanks for the suggestions. I placed my order with Ruben at DesertMotorWorks.
The Powerflex are just a tad too stiff for my daily drive (about 100-150 miles per day).
Old 10-20-2008, 08:04 PM   #17
TxZHP04
Yes, and powerflex squeak requiring them to be lubed periodically. Either way, you have routine maintenance. I've had urethane RTABs and switched back to OEM M3 bushings with limiters and feel this is the superior solution.
Old 10-20-2008, 08:23 PM   #18
jpr
My Ride: '99 323i
Regarding the orientation of the slot, here's the TIS instruction on bushing replacement.
Old 10-20-2008, 08:27 PM   #19
silentak1
Banned
I must be a little slow today... can't tell if the orientation is vertical, horizontal, or slightly at 70 degrees compared to flat ground.
Old 10-20-2008, 08:31 PM   #20
GRIDLOCK
My Ride: E36 / E46
Woot!
Have an EVAP code? Replacing gas cap did not fix? Give me a holler, I can do a smoke test for ya.
GRIDLOCK is offline   Reply With Quote
