Sponsored by BimmerWorld
Old 10-20-2008, 10:15 PM   #21
TxTorqueMade
My Ride: 330i
Send a message via Yahoo to TxTorqueMade
Sounds like in reality most are moving away from the Powerflex phenom...huh?
My Indy said regarding the FCABs as well, they squeek. Thinking Ill go with Meyle HD all the way around and maybe some of those Motorsport control arms for 2k
BMW e30 Bling
TxTorqueMade is offline   Reply With Quote
Old 05-26-2009, 07:11 AM   #22
ssm1991
My Ride: 2004 325i
Was supposed to put in the M3 RTABs with Rogue Engineering shims today but ran out of time. Flexing both RTAB brackets with the original RTABs (half-casing) still felt very firm.
So I just installed the shims on the original RTABs just to check out the difference. What I noticed after installing the shims was that even with the RTAB bolt torqued to the spec 81 ft-lbs, with some force I could rotate the bracket around the RTAB unlike before. I noticed this while trying to do the 16mm bar (pre-loading) routine in the TIS and Bentley. So instead of the RTAB metal sleeve being fixed and unmovable relative to the bracket like before, the bracket and shims are now sliding/rotating against the RTAB rubber protrusions.
So basically it now acts like a bearing instead of a springy bushing. Is this the correct behavior for the shims or did I get ones that are a tad too thick and caused the bracket not to lock with the RTAB metal sleeve?
ssm1991 is offline   Reply With Quote
Old 05-27-2009, 11:08 PM   #23
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
^^The bushing can still rotate. The flex is gone with the limiters - that's what matters
phamine is offline   Reply With Quote
Old 07-13-2010, 09:04 PM   #24
cunninglinguist
My Ride: 2003 LSB M3
Great info! Thanks guys... I'll be referencing this with my purchase.
03 M3Laguna Seca Blue
cunninglinguist is offline   Reply With Quote
Old 07-15-2010, 11:50 AM   #25
AMCINK
My Ride: 2000 323CI
Originally Posted by silentak1 View Post
Thanks for the suggestions. I placed my order with Ruben at DesertMotorWorks.
The Powerflex are just a tad too stiff for my daily drive (about 100-150 miles per day).
How can I contact ruben and how much did it cost? - I like your set up
AMCINK is offline   Reply With Quote
Old 09-29-2010, 09:15 AM   #26
tedfredrick
My Ride: 2001 325I
The way the bushings are supposed to work is that the rubber is supposed to do all the flexign the metal inside and outside is supposed to remain stationary in resepect to the part they are bolted to. That way there is no wear on the metal parts
2007 BMW 328I handiling package
2001 E46 325I
1927 Ford Track T 350 Chevy
tedfredrick is offline   Reply With Quote
Old 01-19-2013, 03:01 AM   #27
E46Cherry
My Ride: 2003 M3
Didn't mean to revive an old thread but which limiters are the favorite? Vorschlag? Turner? Others? And should I just match it with the OEM rtab's?
E46Cherry is offline   Reply With Quote
Old 01-19-2013, 02:04 PM   #28
LittleBear
My Ride: 2001 330i
Hello BMW Experts!
I had m3 RTABs + limiters, and they felt very good at first. Mine were totally shot at ~ 43k miles, though.
So I recently put in UUC red urethane RTABs, which have a 75A hardness rating, softer than the powerflex (85a & up) ones, etc. They also have big channels which should help hold extra grease, making the intervals between re-greaseing longer & lessening the noise potential (mine are silent).
Of course these things are hard to really compare, but I think they make the car more stable than the m3/limiter combo. They should last much longer without deteriorating (if greased properly initially) also. They might take some kinds of bumps a little harder, but generally they have no NHV drawbacks.
YMMV!
Murf
"The Indian smiles, he thinks that the cowboy is his friend. The cowboy smiles, he is glad the Indian is fooled. Now he can exploit him"
LittleBear is offline   Reply With Quote
Old 01-19-2013, 04:43 PM   #29
sakumaxp
My Ride: 02 M3 convertible
i bought the powerflex polyurethane RTABS. love them
Carbon Black Metallic
SMG II
Verttttt
VCSL Front Bumper
VCSL 1 Piece Splitter
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
sakumaxp is offline   Reply With Quote
Old 01-20-2013, 12:29 PM   #30
LittleBear
My Ride: 2001 330i
Sakumaxp,
How long have you had them, & do you have noise?
Do you know the durometer # for the ones in your car?
Murf
Old 01-20-2013, 12:49 PM   #31
sakumaxp
I have had them for a little under or just about a year, and no noise, and about the durometer # sorry I don't, I just told my shop what I wanted and they took care of the rest. Once you get them in you can feel a big diff, the rear will feel more planted to the ground
SMG II
Verttttt
VCSL Front Bumper
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
