Old 10-19-2008, 11:35 AM   #1
christraylor2
My Ride: 2002 325CI
Need Some Help.... Please
Alright, so my car threw the CEL for my thermostat and coolant level, I repaced the thermostat and refilled the coolant, so that should have been that. However, right when all this was happening, my heat started to not work. Yesterday, I opened up the bleeder screw and 'bled' the cooling system, thinking there might be some air bubbles, there was, I watched them come out, then sealed the screw up and went on my merry way. For about 6 hours, my heat was working good, however, later on in the night, when it was actually cold... nothing. I am hearing this 'squealing' sounds too whenever I accelerate or rev around 2,100-4,000 RPMS. I am wondering if there is a leak of air into the cooling system that I will have to continually bleed in order to work or what might be going on. My car doesn't overheat at all and stays normally right around the noon mark on the temp gauge. Any and ALL help would be appreciated.
christraylor2 is offline   Reply With Quote
Old 10-19-2008, 12:11 PM   #2
willsbma
My Ride: 99 323i
Sounds like you might need a new water pump. Try bleeding the system again though, if there is air in there it might have caused a pocket again and that's the problem. Check over all of your pulleys too.
Matte Black Kidney Grilles | Smoked Tails & Corners | Mtech II Bumper | Hotchkis Springs | ACS Roof Spoiler | M3 Spoiler | 20% Tint
WTB: Black sun visors & grab handles - PM ME!
I have P.A. Soft and a 20-pin adapter. Only used it a few times but pm me if you need anything coded!
willsbma is offline   Reply With Quote
Old 10-19-2008, 03:32 PM   #3
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
He is correct you have an air pocket in the system. It also may be a fauly pump do your hoses get hard and can you see a flow of coolent in your expansion tank
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
bleed, cel, coolant, heat, thermostat
