Sponsored by BimmerWorld
Old 10-11-2008, 10:15 AM   #1
Golden330ci
My Ride: 330ci
new rotors new pads....doesnt fit?
im putting on brembo disc and akebono pads...put the rotor and new pads in but cant spread the caliper apart far enough for it to slide on the rotor? what do i do. thanks guys
Golden330ci is offline   Reply With Quote
Old 10-11-2008, 10:18 AM   #2
Bootsma
My Ride: Is black
depends if theyr wind back or push back i guess, if theyr push back get a power bar or something and evenly force them back if theyr wind backu may need a tool.
Bootsma is offline   Reply With Quote
Old 10-11-2008, 10:40 AM   #3
Golden330ci
My Ride: 330ci
trying everything and its still not on....should i shave the pads?
Old 10-11-2008, 11:12 AM   #4
Chris-TK
My Ride: Mk VI GTI
No just get some clamps to fully compress the caliper. Even at a maximum opening there will be very little clearance with new pads. Just get a compressor.
K.
Chris-TK is offline   Reply With Quote
Old 10-11-2008, 11:14 AM   #5
chris98891
My Ride: '16 X6 50i
Send a message via AIM to chris98891
and make sure your brake fluid cap is slightly unscrewed (enough to let air escape)
-Chris
chris98891 is offline   Reply With Quote
Old 10-11-2008, 11:14 AM   #6
BrianJ1888
My Ride: 330i ZHP Imola Red
you need to use a big c-clamp to press the piston back into the caliper, otherwise you'll never get the pads on. pop the brake fluid cap and put a rag around the filler to catch anything that might come up. then use the c-clamp to push the piston all the way into the brake caliper.
BrianJ1888 is offline   Reply With Quote
Old 10-11-2008, 11:26 AM   #7
SLVR JDM
My Ride: 4Runner
C clamp or a big wood working type clamp should do the trick. You can really get the force necessary to push back the piston with the latter.
SLVR JDM is offline   Reply With Quote
Old 10-11-2008, 11:35 AM   #8
Chris-TK
My Ride: Mk VI GTI
Or if you have really strong hands you might be able to bare knuckle it.
K.
Old 10-11-2008, 11:45 AM   #9
shady3one3
Banned
shady3one3's Avatar
My Ride: gets replaced soon.
Send a message via AIM to shady3one3
get a c-clamp or some big vice grips...put one of the old pads on the piston and bottom it out
shady3one3 is offline   Reply With Quote
Old 10-19-2008, 11:41 PM   #10
Gorzun
My Ride: 330
Big channel lock is what I see everyone use!
Gorzun is offline   Reply With Quote
Old 10-20-2008, 12:47 AM   #11
Chris-TK
My Ride: Mk VI GTI
So we haven't heard from the OP in over a week, I'm guessing he either took our advice and was able to finish the install or he ended up driving around without pads and had an accident.
K.
