Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 06-28-2010, 03:11 PM   #41
Snik
Snik's Avatar
My Ride: IR M3 Vert.
i dont think there is enough material to widen it rayce.
BUT, didnt E36 M3 guys do something similar with the 540 HFM on their cars, im sure one of BMWs older motors have a compatible mechanical TB that can fit.
Do you ride a sportbike?
Snik is online now   Reply With Quote
Old 06-28-2010, 03:14 PM   #42
JD_RFTR
My Ride: BMW 323Ci E46
Look for posts of @Icemann on forum, he did the swap
JD_RFTR is offline   Reply With Quote
Old 06-28-2010, 04:03 PM   #43
Iceman00
Banned User
My Ride: E90 6MT
Originally Posted by Rayce185 View Post
Easy: http://www.turnermotorsport.com/html..._ID=TEN9990850
fits your M52TU TB onto the M54 manifold.
My bigger question is: Is it possible to keep the diameter of the B30 setup by either converting the B30 TB to mechanical throttle, or to widen the M52 TB from 2.5" to 3.0"...? I have all components here for the conversion, even that adapter. I just want to know if there is a possibility for this, because the smaller TB and following intake components would act as a restrictor...
A larger TB isn't really worth any power.
Old 06-28-2010, 04:05 PM   #44
Snik
Snik's Avatar
proof? just curious how u know this
Old 06-28-2010, 04:17 PM   #45
Iceman00
Banned User
My Ride: E90 6MT
Because the TB isn't a restriction.
Old 06-28-2010, 04:18 PM   #46
Snik
Snik's Avatar
so why does dinan and a few other tuners offer larger TB fr our cars?
Old 06-28-2010, 04:21 PM   #47
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
I don't think it's worth MUCH power, especially if you don't have a lot else going on. I'll be hitting the dyno with one fairly soon. I'll post up results.
Old 06-28-2010, 04:29 PM   #48
JD_RFTR
will be waiting for the dyno.
what about the swap, as I know, iit`s worth because of gain of HP not torque, HP gains are at high rpm, but you can lose torque on low rpm. THis is the difference between manifolds of m52b25tu and m54b30. Nobody have mentioned gains or lose from TB.
Larger TB`s offered by tuners, may be for the M50 intake, or in case you swap the intake manifold and want also a bigger TB but you don`t want it to be DWB. Check turnermotorsports, you`ll see.
Old 06-28-2010, 05:13 PM   #49
Keno
My Ride: 330ci + 550i
Send a message via AIM to Keno
all those mods listed + wieght loss. Get a LTW battery, take out the spare (and/or put ZHP donut tire in), put in lightweight seats, go on a diet, aluminum catback exhaust...mkodama made a thread about wieght loss, and you can shave about 100-120lbs for free: http://forum.e46fanatics.com/showpos...&postcount=483 LTW seats, wheels, battery, etc will start to dig into your wallet. I remember some company made some lithium ion batteries for our cars...not sure what happened to that though.
Keno is offline   Reply With Quote
Old 06-28-2010, 10:40 PM   #50
zac328
My Ride: is awesome
I'm almost ready to install mine... just need the width of the adaptor plate. i'm having it made by a friend.
Otherwise i have the drawings if anyone wants them...
i'm putting m54b30 manifold on my 328.
So if anyone knows the width of the adaptor let me know.
thanks
I'll get dyno results when installed.
zac328 is offline   Reply With Quote
Old 06-29-2010, 01:17 AM   #51
Rayce185
Modifiziertes ///Mitglied
Rayce185's Avatar
Do you have pre-install dyno results too? For comparisson?
dun dun duuuunnnn
Rayce185 is offline   Reply With Quote
Old 06-29-2010, 04:05 AM   #52
zac328
My Ride: is awesome
not up to date with what's on the car but i'll see how i go for time... would be good getting some comparison for this mod.
Old 06-29-2010, 05:54 AM   #53
Snik
Snik's Avatar
awesome zac, looking fwd to seeing dyno results and hearing your impression.
Old 06-29-2010, 12:48 PM   #54
Iceman00
Banned User
My Ride: E90 6MT
I'm not sure I'm understanding what is going on here, but let me clear a few things up:
I did the M54B25 manifold swap from the M52TU and there is a noticeable increase in power in higher rpm, and no perceptible loss of power before the DISA switch over. As far as the larger bore Throttle body goes, I don't believe there is much to be gained there. Hovering Guy is using a smaller diameter throttle body from an M50 motor, and still managed to make about as much power as Jackeatsemokids did with custom tuning. This leads me to believe that the throttle body is flowing as much air (or more) than the head, meaning it's probably not a limiting factor. Is there power to be gained? Perhaps, but unless it's cheap, it's probably not worth the effort.
Old 08-01-2010, 02:27 PM   #55
akb4
My Ride: is gone :(
bump! any info on swapping bottom end with an s52 onto an m52tu head?
akb4 is offline   Reply With Quote
Old 08-01-2010, 10:26 PM   #56
zsp
My Ride: 328
1. Don't buy useless bolt-ons that will barely yield any hp/tq
2. Save up for boost
3. ????
3. Profit
zsp is offline   Reply With Quote
Old 08-02-2010, 08:46 AM   #57
hoveringuy
My Ride: e30
This is true. My tiny M50 TB had a negligible impact on power.
I finally upgraded to an M54-size throttle body...
Initally, throttle response feels better, but I think that's because it gets to X airflow at a higher pedal position (same throttle plate angle has more airflow). After a few days of driving that goes away when your foot recalibrates.
Power feels the same. I may have 3-5 more HP at the top end but my ass isn't calibrated well enough to say for sure.
BMW put the M50 TB on the S50, I'm sure they wouldn't have done that if it cost them more than a few HP!
hoveringuy is offline   Reply With Quote
Old 08-11-2010, 08:01 PM   #58
BadBoostedBmwM3
My Ride: 323i & e36 Turbo M3
Very interesting! I would love to see some dynos of the a m54 IM swap to a m52tu. A nice (cheaper) power increase for my 323i.
This is my signature....
BadBoostedBmwM3 is offline   Reply With Quote
Old 08-16-2010, 04:57 PM   #59
JohnBlaze
My Ride: Black Sunshine
thanks
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Old 12-02-2010, 12:26 PM   #60
dco5000
My Ride: 2000 BMW 323ci
M52TU Head Swap for an M54?
Originally Posted by ledfut View Post
As far as I know, from reviewing part numbers and the like, the cylinder heads on the M52TU and M54 are the same.
Facing the need to get a new head from my cracked m52tu. Any more confirm / deny on ability to use a m54 head as a direct bolt-in?
Thanks all!
dco5000 is offline   Reply With Quote
head, m52tu, m54, manifold, swap
