Old 10-26-2008, 01:30 AM   #1
George Hill
My Ride: 2001 R1100S
Reparing M52TU cylinder head bolt threads
I have done extensive searching on the forum here for threads on the actual thread repair, but have had no luck.
My questions are does anyone have some real life experience performing this repair?
I found the jig kit from Baum tools but are there any other options?
Thanks, George
George Hill is offline   Reply With Quote
Old 12-06-2008, 06:14 PM   #2
George Hill
Well, I searched and searched and was unable to find firsthand experience of performing the repair. The update is that it works... at least so far.
Removed the cylinder head. Had it pressure chaecked and machined flat (removed .013"). BMW sells a head gasket that is .30mm than stock and .013" = .33mm. Bought the jig form Baum tools and sourced the timeserts kit and inserts locally. Removed the engine from the vehicle and performed the repair to the headbolt threads. Install repaired head with new gskt and bolts.
Vehicle has 70 miles on her so far, runs like a top.
Old 12-08-2008, 09:51 AM   #3
mrshelley
My Ride: 2004 330i
I did a repair in the car on one and bought heli coils from McMaster Carr. I made a jig (flatstock and a bushing I bought from McMaster Carr), drilled the holes with a hand drill and then installed the Heli Coils. If you buy 20mm long Heli Coils and stack them, it'll work fine.
Old 12-08-2008, 10:12 AM   #4
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Sweet! Way to tackle it yourself. Hope it holds up for you!
Old 12-08-2008, 06:28 PM   #5
George Hill
I used 25mm long timeserts. I'm not sure if I would trust a heli coil for this application. How many miles do you have since the repair?
Aggie, We will never know how long it would have held. Sat night I put it into a bridge support, cracking the block and the head.
Old 12-08-2008, 08:25 PM   #6
mrshelley
My Ride: 2004 330i
As for the repair, I did this back in early 2005 and the car is still driving around today. I haven't heard one complaint. Looks like to me, it held.
Also, I did this to one of my race engines and it held fine for a year until the oil pump chain broke and it sent a rod through the side of the block. Good thing is this, the Heli coils held up.
Old 12-09-2008, 08:25 AM   #7
hoveringuy
My Ride: e30
I did it 300 miles ago. Baum will sell you the 25mm inserts, I wouldn't use those.
Get the 30mm inserts direct from TimeSert.
Good to go so far.
hoveringuy is offline   Reply With Quote
Old 12-15-2008, 04:03 PM   #8
dirtbiker245
My Ride: 00 323ci, 02 325i
Ive talked with alot of guys who have done head gasket replacements since I own the tools and let people use them when needed. Ive known two people to use the timeserts and their motors went back together perfectly fine with no problems yet to this day. Time serts definitely seem the way to go on these motors if you have a bolt that wont hold torque.
dirtbiker245 is offline   Reply With Quote
Old 12-19-2008, 12:57 PM   #9
hoveringuy
My Ride: e30
I knew of one guy up here in Seattle who used the Baum kit with those shorter inserts and they pulled.
Aluminum will anneal as it heats so if you totally roasted the motor you may have weakened the aluminum to the point that it's scrap. If you turned the motor off as soon as you saw the red light you are fine.
Just go with the 30mm inserts. My $.02.
Oh, and props to DirtBiker for my tool rental. He's got what you need!
www.seattlecircuit.com
Old 12-19-2008, 05:59 PM   #10
George Hill
For clarification the Baum tool does not come with any inserts anymore at least. The timesert kit comes with 10mm inserts, may have been what the guy up north used. When I got my timesert kit all I could find were 25mm or i would have used the longest I could.
Old 02-17-2011, 06:27 PM   #11
wardpower
My Ride: 99' 328i Sedan
I have a leak between cylinders 5 and 6 and am thinking about doing the head gasket DIY myself and sending the head to a local machine shop. I turned my car off as soon as it went red and it only happened once so I don't think I roached the motor, I'm surprised I blew the head gasket at all. Should I order some inserts before I start tearing it apart? How to I test to see if they still hold torque? Is it likely that they'll still be good?
wardpower is offline   Reply With Quote
Old 02-17-2011, 06:27 PM   #12
wardpower
Also forgot to ask in the last post, does the engine need to be pulled in order to do the rethread?
Old 02-17-2011, 09:44 PM   #13
amdspitfire
My Ride: 328is, 330cic, 335i
The first thing to do is to test the threads in the block with your existing head bolts. There is a sequence to loosen the bolts, find that and lose all the bolts. Then find the proper torque/angles to tighten the head bolts and see if you can reach the proper torque. My head bolts held fine to the last step when they would just give up. The threads in the block were no good on almost all of mine.
You can repair the block with it in the car, just have to remove the head. The actual repair work is not difficult at all. If you are going to do the repair you might as well do all threads.
Let me know if you have any other questions. I have the kit for sale as well if you are interested:
http://forum.e46fanatics.com/showthr...810&highlight=
amdspitfire is offline   Reply With Quote
Old 02-17-2011, 10:35 PM   #14
wardpower
Thanks for the info man, I may PM you about buying that.
Old 02-23-2011, 03:23 PM   #15
wardpower
I heard the the threads in the block are 6mm deep. How do the kits work with this, is a 6mm deep counterbore drilled? Is it also done this way with the 30mm flush kit, or is the hole's diameter drilled out enough that the threads can be cut starting from the top?
I'm trying to figure out if I should buy the 24.5mm bmw kit, buy the 30mm flush kit, or get the standard m10x1.5 kit and buy inserts for it. Then if I got the standard metric m10x1.5 kit what size inserts would I be able to use on an M52TU engine block, as they make inserts up to 40mm long?
Old 04-28-2011, 03:02 PM   #16
tbgreen21
My Ride: 1999 323I E46 M52
Drilling
The preoceedure can be completed without removing the engine. Of course it would be easier if the engine was removed and placed on a stand exactly level. If yo have to remove the engine for other reasons do the repair while its out. Reguardless of the location of the engine. Tape the block face with Duct or painting tape (minimize the sticky face) leave the bolt holes untaped. the Helicoil kit will dictate the drill bit size. Dont worry so much about the coil lengths, If you can get the long inserts then buy them (they can be shortened by snipping off some of the coils with a sharp pair of side cutters. After you get a NEW (not a old dull bit) drill bit (not provided in the kit) then use a triangle square to make sure you are drilling straight. You will be only drilling out the old threads. The original hole will guide the bit so you do not need to force it to go straight. The drilling is NOT done at High speed.
1. Position the drill and Drill slow and steady.
2. Clear the hole of material with air
3. Spray the re-threading bit with some type of oil ( I use a light lube oil spray) and insert it in the "T" handle, check it with a triangle square then slowly twist it into the hole to cut the threads. when it gets hard to turn clear the cuttings with air . If the bit seems it will not turn remove it and clear the hole and bit of shavings then insert it again and continue until the entire hole is threaded.
4. Clear the new threads with air
5. Position the coil on the coil threading tool and slowly twist the coil into the new threads. (no oil) a. (if using short coils remove the tang of the coil after each coil in inserted and clear it from the hole with air. (( done with a round flat tip punch NOT camphered)) continue inserting coils and removing the tangs until the hole is filled to 1/8 to 1/4 "" from the block surface)
6. Test the finished repair by hand threading an old head bolt( good condition) into the new threads
DO NOT TIGHTEN THE BOLT WITH A WRENCH at this time.
Inspect ALL the other head bolt threads with a flashlight , If any look like they are mashed, stretched, jagged, or damaged in any way do a repair NOW or waste $100.00 for another head gasket later.
RULE of THUMB if the engine was overheated and one(1) of the headbolts won't tighten, Then ALL the headbolts threads on the Exhaust side are weakened and may or may not tighten to spec's ( the exhaust side gets much hotter and will change the strength of the aluminum on that side first)
Finally after all holes needing repair are done remove the tape and spray a quick dry cleaner on the surface then wipe clean and blow dry with air.
You are now ready for the new head gasket !
I have some Picks of my last repair and I will try to post them to this thread.
Good Luck
tbgreen21 is offline   Reply With Quote
Old 04-28-2011, 03:16 PM   #17
tbgreen21
Make sure you take the Head to a reputable shop to get at least three things tested and done;
1. Chemical clean ( no HOT TANK)
2. (two tests in one) Test for cracks. Pressure test for valve seal. ***The heads crack all the time into a water jacket channel and can not be repaired easily. If it is not cracked you are good to go to number 3 ****if cracked look for a replacement (repair not cost effective)
3. Straigness (no warp) resurface it to make to flat again. Record the amount shaved to see if an oversized head gasket is needed.
Treat the steel parts with a light oil if the head is to sit and wait around to be reinstalled
check my post on headbolt threads
tom
Old 05-26-2011, 02:31 PM   #18
tommytoyz
My Ride: 1999 e46 323i
tom
Where can one find a replacement head if it is cracked in a water jacket? How much do these usually run. Any special considerations when installing a replacement head? Many thanks, excellent thread...
tommytoyz is offline   Reply With Quote
Old 05-26-2011, 03:30 PM   #19
tbgreen21
replacement of cracked head
There are many locations to get another head. It depends where you live. I know a guy who went to LQK and got 3 different heads until he found one that was still good( not cracked) I recommend purchacing one from a company that has a waranty. Remember ***** If the head is removed from another car YOU MUST have it checked for Straightness!!!! ****** even if they say its good I would have a light resurface done. AS for the price I'm not sure. IT depends on the level of what is included with the head ( tapets, cams?)
For instalation, follow the instructions TO THE LETTER . and use the BMW special tools. ( rent them , borrow them ) if you don't use the special tool to isolate the ends of the two cams when you are setting the timing chain and cam chains you can BREAK the cams!!! (very bad). ALSO have someone help you when you lower the head onto the block to make sure the cam chain and guides are positioned properly and you dont put pressure onthe guides( only plastic they can break also) The head and exaust manifold are put together outside of the car, Then lowered together onto the block. The entire assembly is very heavy if you are man handling it and not using some sort of lift.
Old 05-26-2011, 06:52 PM   #20
wardpower
I just finished torquing down my head into time-serts and it held. Now I have two time sert kits to sell/rent. A standard BMW 30mm flush kit and a countersunk big-sert kit.
