Old 10-27-2008, 06:38 PM   #1
paraklas
My Ride: ESS TS2 320ci
Effect of Leaking Valve Cover Gasket on Supercharged Engines
As per title, you can guess my newest problem. I was detailing the engine yesterday when I noticed oil deposits on the front/lower part of the gasket, almost below spark #1. I cleaned it thoroughly and today it's got oil at the same spot. I believe that's the cause of the burning oil smell in the cabin There's also some oil in the spark plug #1 tunnel and it's not from the oil change.
I would like to know how/if this issue affects the engine now that it's supercharged with the ESS Twin Screw. Can it cause issues like rpm drop below idle mark etc?
I will of course replace the gasket plus the 6 small round gaskets but I'm a bit pressed on time right now and thinking to postpone it for 3-4 weeks.
Thanks,
Paris
Old 10-27-2008, 07:04 PM   #2
MSpired
My Ride: HPF Stage 2.5 e46 M3
Send a message via AIM to MSpired Send a message via MSN to MSpired Send a message via Yahoo to MSpired
Sucks bro, hope you get it figured out as soon as possible.
MSpired is offline   Reply With Quote
Old 10-29-2008, 11:40 AM   #3
paraklas
Thanks, I will replace it asap.
There's some debate regarding the use of high temp silicone gasket sealant in conjuction with the OEM gasket, any opinions on this?
Old 11-02-2008, 08:35 PM   #4
thegrk
My Ride: BMW e46 328i 1998
If your the hole is big enough to loose presure inside the rocker cover then it would explain rpm drops.
thegrk is offline   Reply With Quote
Old 11-03-2008, 04:59 AM   #5
paraklas
It's dripping oil right now, so I'll say it's big enough. Ordered the gasket now from dealer, along with the 6 individual ones and 15 rubber seals.
blown, cover, gasket, twinscrew, valve
