Old 10-27-2008, 06:04 PM   #1
Franxta
My Ride: 325ci
Send a message via AIM to Franxta
Exclamation Need A DIY on amp install.
hey everyone,
im looking for a DIY on how to install a mono amp on a 2001 325Ci. im planning on mounting to the seats it in the trunk behind the subs. ive figured out i need an LOC. where do i go from there?
thanks
-Frankie
"But the speed was power, and the speed was joy, and the speed was pure beauty."
--Jonathan Livingston Seagull
Franxta is offline   Reply With Quote
Old 12-11-2008, 03:52 PM   #2
Dannyncc
My Ride: Aw m3
Send a message via ICQ to Dannyncc Send a message via AIM to Dannyncc Send a message via MSN to Dannyncc Send a message via Yahoo to Dannyncc
nope?
Dannyncc is offline   Reply With Quote
Old 12-11-2008, 06:29 PM   #3
BmwAudio32
My Ride: 2004 Imola 330i ZHP
Hey man, you are correct, you do need a LOC. Mounting the amp there and getting power/ground to it should be very easy, as you know the battery is right there in the trunk. Now, with that out of the way, you simply need a signal, and a remote turn-on. The remote turn-on lead is found in the factory amp harness behind the driver's side trunk trim (easily removed). The LOC will also wire up back there. Here is a pretty good guide on how to do it:
http://bavariansoundwerks.com/produc...oupe_99-06.pdf
Difference being you will use a LOC on the wires, then run RCA's, unless you get a subwoofer amp like the BSW one that can take the signal directly.
BmwAudio32 is offline   Reply With Quote
