Old 02-25-2017, 02:37 AM   #1
timmieg88
My Ride: 330ci
Vanos problem after rebuild
Hi I recently rebuilt my engine for turbo setup e46 m54b30 dual vanos
My vanos is not working it's down on power and hard to start. It's not throwing any codes.
when I go on Inpa diagnostics and view the vanos status, all the data is frozen! Dosnt appear to be working at all
any ideas what could cause this?? I'm sure it's timed up right I used the kit. Even if the sprockets were slightly off you'd think I would still get live data in inpa??
Is it possible I have overtightend the nuts on the sprockets?
Thanks for any help
timmieg88 is offline   Reply With Quote
Old 02-25-2017, 03:45 AM   #2
indee321
It may have nothing to do with it but when i rebuilt my vanos seals for some reason my exhaust solenoid immediately started sticking and needed replacing. It was putting the car into limp mode all the time. I even had a mechanic take apart the vanos unit to check my work (it was fine) before we eventually diagnosed the solenoid
Sent from my SM-A300FU using E46Fanatics mobile app
indee321 is offline   Reply With Quote
Old 02-25-2017, 03:52 AM   #3
timmieg88
My Ride: 330ci
How did you test the solinoid?
Old 02-25-2017, 04:22 AM   #4
indee321
Here is the thread i started about it.. i got the codes read and it said something about exhaust solenoid not reached.
http://forum.e46fanatics.com/showthread.php?t=1106069
problems post vanos seal replacement
Old 02-25-2017, 04:45 AM   #5
timmieg88
My Ride: 330ci
I'll check that thread out. What's bugging me is the inpa diagnostics the live data is frozen on the vanos status and the rough running page. All other diagnostics is fine. Maybe the exhaust can sensor ingested some water or something when I rebuild and pressure washed the head
Old 02-25-2017, 05:20 AM   #6
timmieg88
My Ride: 330ci
Ok so I now have a code 83 kw no signal. I beleave this is the crank sensor! How is the engine running if it has no signal from the crank?
Old 02-25-2017, 05:42 AM   #7
indee321
Hmm thats a little beyond me sorry.. im sure a helpful fanatic will be along soon
