View Poll Results: Have you ever used Seafoam?
Yes, I highly recommend it. 58 37.91%
Yes, But I dont recommend it. 8 5.23%
No, But I have thought about it. 60 39.22%
No, I would never do it. 10 6.54%
No, I have mixed feelings about it. 18 11.76%
Multiple Choice Poll. Voters: 153. You may not vote on this poll
Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average.
Old 12-02-2008, 04:21 PM   #241
Custom3
My Ride: HellRot 330CI
yes and O2 sensors...and checked for vacuum leak...nothing
Originally Posted by n2Bimmer View Post
your the first person ive heard have issues, did you change your spart plugs??
Old 12-02-2008, 04:26 PM   #242
jeffro3000
My Ride: 2000 328i
i wouldnt want to put something like that in my engine when it's running perfectly fine now...
jeffro3000 is offline   Reply With Quote
Old 12-02-2008, 04:26 PM   #243
n2Bimmer
My Ride: Loves Corners
intresting, did you spray or pour it into your intake, how fast, how much. when did the light turn on. when did you change your oil.
Old 12-02-2008, 04:29 PM   #244
Custom3
i poured it into the vacuum hose very slowly...put it in the oil and gas tank as recommend...the light came on instant...i cleared it...and it would come up again....i changed the oil a week later...which was probably 80 miles later.
Old 12-02-2008, 04:32 PM   #245
k7780446
My Ride: 323i
i never heard of putting it in your oil before just gas and vacuum line
5492_121783803182_586518182_2342960_2124492_n
k7780446 is offline   Reply With Quote
Old 12-02-2008, 04:33 PM   #246
kan
My Ride: 2006 330CI
Then what code you get?
kan is offline   Reply With Quote
Old 12-02-2008, 04:36 PM   #247
Musikpro
My Ride: 2005 BMW 325i
I think it says it on the bottle under the "uses" section. I've used it in my oil and gas... no problems.
Transportation at its Best :)
Musikpro is offline   Reply With Quote
Old 12-02-2008, 04:37 PM   #248
k7780446
My Ride: 323i
hmmm maybe i got a different kind or i just missed that haha owell
Old 12-02-2008, 04:37 PM   #249
n2Bimmer
OH MY LORD, why did you pour it into your oil, whyyyy, did you read the DIY, it never said to do that, You have to pour half into your vacuum hose, pour the other half into your gas tank then SPRAY another half VERY VERY slowly into your intake tubing. You need two cans, aaaahhhh man, and also one week is way to long, you should have drove the car 50 miles that same day and changed the oil the next day.
Old 12-02-2008, 04:40 PM   #250
k7780446
My Ride: 323i
ok so im not the only one who didnt think you should put it in the oil haha i know it said to change your oil and plugs soon after but not put it in your oil....but again i could be mistaken lol
Old 12-02-2008, 04:42 PM   #251
n2Bimmer
nope i never read into oil, oh i never changed my plugs, its cool, i changed it a year before i did the seafoam.
Old 12-02-2008, 05:31 PM   #252
Custom3
the diy i read said 1/3 into the intake tubing....1/3 into the oil and 1/3 into the gas tank it even says it in the can
a had a few codes and changing the spark plugs and o2 sensor removed a lot of the codes...now im only down to one code...which is o2 sensor to lean or something like that...comes up once in a while, not all the time...indicting a possible air leak somewhere...now that its cold outside im getting condensation in my oil...i wondering if the seafoam is the culprit and the code im getting has something to do with the condensation i been getting
Old 12-02-2008, 05:41 PM   #253
n2Bimmer
no it cant be, maybe the oil cap is bad??, you drained the oil remember. You pour into intake, vacuum line and tank.
Old 12-02-2008, 05:45 PM   #254
n2Bimmer
Seafoam DIY http://forum.e46fanatics.com/showthr...hlight=seafoam
Old 12-02-2008, 05:45 PM   #255
Custom3
yeah i drained it but i im wondering if the seafoam ruined my head gasket...i see a very very small leak....could water condensation go into the engine if the gasket is bad?....im planning on replacing the gasket this spring.
Old 12-02-2008, 05:47 PM   #256
Flipe46d1722
My Ride: 2002 325ci
Send a message via AIM to Flipe46d1722
I've never heard of it going in your oil either. I did it on my e46 and its got bout 75 on the clock. Let the ***** sit for like 2 hours and that **** smoked so much half my neighborhood was under it!! Def feels better, I did vaccum tube.
Flipe46d1722 is offline   Reply With Quote
Old 12-02-2008, 05:52 PM   #257
n2Bimmer
i dont think so unless its huge, if you got condinsation in your engine your would really F it up. You need to see a mechanic if you have not.
Old 12-02-2008, 05:53 PM   #258
Custom3
looks like im the only idiot who put it in the oil then
Old 12-02-2008, 05:53 PM   #259
koven
My Ride: 330Ci
i think im gnna do this.. i got 90k miles
someone told me i should do it before my next oil change.. does it matter?
koven is offline   Reply With Quote
Old 12-02-2008, 05:57 PM   #260
Custom3
from reading the threads its normal in the winter time.....some of the oil looks like a white cream....looks nasty but from what i have read its normal
blue, cleaner, dmax, engine, fuel, gas, injector, injectors, intake, seafoam, smoke, suction, tank, white
Rate This Thread
