View Poll Results: Have you ever used Seafoam?
Yes, I highly recommend it. 58 38.16%
Yes, But I dont recommend it. 8 5.26%
No, But I have thought about it. 59 38.82%
No, I would never do it. 10 6.58%
No, I have mixed feelings about it. 18 11.84%
Multiple Choice Poll. Voters: 152. You may not vote on this poll
Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average.
Old 05-22-2008, 10:35 AM   #101
n2Bimmer
My Ride: Loves Corners
do it, dont be scared, its really easy, but do not pull the vacumm line out of the plastic, just pull the plastic along with the tube. I was able to remove the tube by itself, and make sure you cover your MAF sensor. JUST DO IT.
Old 05-22-2008, 10:36 AM   #102
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Did you change your plugs after you ran it through? From experience, it doesn't do good things to spark plugs.
Old 05-22-2008, 10:52 AM   #103
LKNGOOD
My Ride: 2007 BMW 335i
I did it - Everything went well for me too. I didn't take of the clamp - just pulled the entire hose off and then pushed it back in when I was done. I let the hose suck 1/3 of the bottle and put 1/3 in the gas tank and the remaining 1/3 in the oil.
Let the engine sit for 15 minutes and then started her up - it smoked for about 5 minutes and then it was done. I also changed the oil afterwards.
Honestly can't say I feel any difference - car been running fine - no issues.
It's been 5k now and gonna do another oil change and possible new plugs (Last changed 30k ago)
Later,
Mike
* 2007 BMW 335i - 6sp/manual
LKNGOOD is offline   Reply With Quote
Old 05-22-2008, 12:28 PM   #104
jmueller
My Ride: 2001 330ci
i seafoamed 20000k before i changed my plugs.. they were fine when i pulled them just a little worn from 50k worth of use
jmueller is offline   Reply With Quote
Old 05-22-2008, 12:33 PM   #105
n2Bimmer
same plugs here, i replace them at 50k miles, i now have 70k miles.
Old 05-22-2008, 05:01 PM   #106
Knight2424
My Ride: E46, 3000GT
i heard that the seaform messes your o2 sensors.
MOD LIST: UUC TSE3 Exhaust, Predator Chroniums, Simota CF Intake, Depo Smoked Corners, Custom Alcantara Shift boot, ZHP Wheels, ZHP Shifter, CSL V1 Bumper, Euro-Spec Carbon Fiber CSL Trunk, Ceramic Tint , M// Steering Wheel, EE LEDs Tail lights, Optima Red Top Battery, 2-12" L7 Solobarics, 2000wtts D-class Hifonics mono amp,NGK Iridium plugs.
Knight2424 is offline   Reply With Quote
Old 05-22-2008, 05:30 PM   #107
cohjos
My Ride: 2001 325I
it doesnt mess it up, they just get dirty or something and it gives you a CEL sometimes but as you drive the deposits will go away as the light will too.
i recommend doing the sefoam DIY.
cohjos is offline   Reply With Quote
Old 06-03-2008, 10:08 PM   #108
eek142
My Ride: E46
Seafoam users: How many miles did you drive before changing oil?
Been considering cleaning the engine out using seafoam but I know you must get an oil change afterwards since it becomes contaminated after. I have read people saying they changed it immediately after and other saying they changed it within 3000 miles...
It seems to me like changing it immediately after could contaminate the new oil since there is still seafoam in your gas tank, which means that the gas that was in the car must be burned off completely.
eek142 is offline   Reply With Quote
Old 06-04-2008, 12:32 AM   #109
zuckuss00
My Ride: F22 M235i JB4
(Bump for later reference)
Also..
I was thinking that myself! I have been recently thinking about running seafoam through my car. I am still skeptical about the product, I read alot of mixed reviews and the possibility of a SES light....? IDK
zuckuss00 is offline   Reply With Quote
Old 06-04-2008, 12:43 AM   #110
FLAT_FOOT
My Ride: L3MANS
Send a message via AIM to FLAT_FOOT
Same here...debating if I should put that stuff into the car......I just changed the oil...so i'll debate in another 7500 miles later...lolz
http://www.mybannermaker.com/link.php?nurl=http%3A%2F%2Fwww.mybannermaker.com%2F][IMG]http://img238.imageshack.us/img238/6656/mybanner4908a36d1f0abir8.jpg
6 Feet Under!....
to be continued......
FLAT_FOOT is offline   Reply With Quote
Old 06-04-2008, 06:25 PM   #111
eek142
My Ride: E46
From what I read, it now seems like people who poured some of the seafoam in their crankcase changed their oil out almost immediately after.
Old 06-04-2008, 06:36 PM   #112
Cobra
My Ride: '00 328i & '06 R6S
yeah, i would do it right away. also, change the spark plugs as well.
Cobra is offline   Reply With Quote
Old 06-04-2008, 07:05 PM   #113
n2Bimmer
my plugs are the same, 3k miles
Old 06-04-2008, 07:46 PM   #114
DJCim
My Ride: '01 M3
Send a message via AIM to DJCim
so correct me if I'm wrong but it is straight to put it in the oil which is the crankcase. I used it in my gas tank but I wanted to put in the oil too but I wanted to see if others have done it and if it worked
DJCim is offline   Reply With Quote
Old 06-04-2008, 10:00 PM   #115
Kmoy2002
My Ride: 2002tii, 540i, 330i
Never did it to the BMWs, but seafoamed the VW and changed the oil right afterwards. Didn't pour it into the crankcase cause enough if it run through the brake booster will make it into the oil.
Kmoy2002 is offline   Reply With Quote
Old 06-05-2008, 11:18 PM   #116
RockLee
My Ride: 99 328i. ZSP, ZPP,
Send a message via Yahoo to RockLee
Question Sea Foam + Brake Booster line.
Hey guys and gals. I need to know How to remove the brake booster tube on a pre-face lift 328i sedan. Where to spray it and what other locations to put it. I have the sea foam deepcreep.
RockLee is offline   Reply With Quote
Old 06-06-2008, 01:39 AM   #117
kpeng
Banned User
My Ride: E46 330 and E30 325
Shut the car off, and just yank at it hard. Wiggle it around and just pull. It'll come out after some convincing, it's hard because it is a vacuum line so it's going to be stuck on.
What I do is, put seafoam in a plastic cup, undo the brake booster line, and then just have a friend hold my RPMs at 2000 while I slowly let it suck in the seafoam a bit at a time. Sit the car for 15 minutes, start it up, and hold the revs up for a bit. It'll start sounding/feeling like it's choking, and you'll get some poopoo spewing out your exhaust.
kpeng is offline   Reply With Quote
Old 06-06-2008, 01:41 AM   #118
rovert
My Ride: is an Individual
Send a message via ICQ to rovert Send a message via AIM to rovert Send a message via MSN to rovert Send a message via Yahoo to rovert
Yup just pull on it hard. It'll come out of that black metal pizza cylinder. Mine sounded like this when I started it after waiting 15 minutes:
--Trevor--
Vancouver, BC
rovert is offline   Reply With Quote
Old 06-15-2008, 05:44 PM   #119
brodaiga
My Ride: 330ci
seafoam another car question
want to seafoam a minivan, plymouth voyager 96. can says spray in the throttle body if not port injected engine. not sure if this car is port injected or what that means. do I just take off the intake hosing going to the TB and spray little by little while the car is idling?
brodaiga is offline   Reply With Quote
Old 07-05-2008, 03:25 PM   #120
KeepUpWithThis
My Ride: 03 zhp
Send a message via AIM to KeepUpWithThis
hey rovert, did you change your spark plugs after this treatment?
Too stock...
KeepUpWithThis is offline   Reply With Quote
blue, cleaner, dmax, engine, fuel, gas, injector, injectors, intake, seafoam, smoke, suction, tank, white
Rate This Thread
